Newby with tube question on a 37-116
I recently acquired a mostly unmessed-with and completely unrestored 37-116. It's in pretty nice shape, not missing too much, and I want to do a correct restoration. I have tried to read as many posts as I could before posting this. I am going to probably have a million question but I will start with just a few:
There is a tube in my chassis labeled 6H6 (Sylvania). Obviously a replacement as the tube layout calls a 6H6G. The original 6H6G is an octal double diode. The 6H6 is a squatty little black tube with no glass envelope, no shield (although the socket has provisions for one) and it does NOT want to come out. I am a little afraid to reef on it. Soooo, is this an acceptable tube for this socket (I would assume it would work with that number), does it need a shield and am I missing something trying to get this thing outta there? I've attached a picture.
Thanks in advance for your help
Chris G
The sub is good. I've newer seen a 6H6 glass tube, but either one will work. You may have to spray a little deoxit or WD40 from underneath the chassis on the socket, and gently pry this tube out with 2 screwdrivers at the same time on opposite sides. Eventually you will get it out. But then again, these seldom fail, so after the recapping, etc... you might be good to go.
Chris,
Make sure that if you decide to use the metal 6H6 detector tube that pin 1 on the tubes' socket is used only for a ground connection and not a tie point for other circuitry. The metal envelope of metal encased tubes act as the shield and their pin 1 is normally tied internally to the metal shield therefore pin 1 on the socket should be ground. On glass envelope tubes such as a 6H6G or 6H6GT pin one may not have been ground but used as a chassis tie point for other components. Glass tubes as you can see often use external metal shields to suppress oscillations and intermodulation effects, etc. Hopefully, whoever changed this tube out looked at this aspect? To my knowledge Philco did not use metal
tubes prior to WWII? If you decide to restore this set to original you may want to install a glass 6H6GT and find a metal shield...it's up to you of course. Glass 6H6GT tubes are not expensive and may be found from many suppliers.
Best wishes on you radio restore. Icon_smile John
John
Thanks for the advice. I am inclined to use the 6H6G with a shield as it is period correct.
Chris
The original tube was likely a 6H6G type, sometimes also called shouldered tubes, but I suspect that they are somewhat harder to find then a 6H6 GT. The 6H6 is a dual diode with no grid cap lead to deal with, and uses a normal Philco tube shield, so you can stick whatever glass tube you like in it's place, a metal tube just looks wrong in there. If it used a Goat type form fitting shied you would want to find a 6H6 G with an ST style glass.
Whatever you find and adapt, a couple of simple diodes could do the legwork. My god, it was about 40 years ago on training can. USNR.
[split] New member...
Far as I know, that plastic insulator should be mica. I don't know if plastic is an equivalent insulator.RodB — 10:51 PM
Ok, I think I'm about done.  I've got one anomaly left but other than that, it is working great and picking up lots of s...HowardWoodard — 09:34 PM
Abandoned Zenith 9-S-367 located/Galesburg IL
As I looked through Zillow I noticed an abandoned house for sale in Galesburg Illinois for $14,900. There appears to be...bridkarl — 05:42 PM
Yesterday checked Mouser for the price on some caps and was curious about the mica equivalent. The 27pf 1kv ceramic is 2...RodB — 09:58 AM
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
There are currently 303 online users. [Complete List]
» 2 Member(s) | 301 Guest(s)
