Midwest 98
Long story but I ended up with this Midwest 98 while getting a 41-255.
 The transformer is toast so I need to find a replacement. It came with a 24R13U which is totally bad. Interesting radio - full of WW2 surplus parts.
Pretty easy restoration once I find the transformer.
There's one on ePay for $95 obo plus 8.40 shipping from LA. So offer 75 and see what happens.
I would try AES, look at the power transformers listed for guitar amps if you need one that is horizontal mounted, or even if not.
I looked but it appears to be gone already.
Try this: https://www.ebay.ph/sch/i.html?_from=R40...acat=67815
Tim Would mounting he transformer vertically change the hum, if used without additional parts? Also, in these amps...morzh — 02:25 PM
Shadow Meter Bulb
Gary I doubt it would introduce any noise. We use similar lamps for the panel indication, 12V AC lamps: they are LEDs...morzh — 02:15 PM
Shadow Meter Bulb
Not sure if anyone has tried this but there are 6.3 volt miniature lamps in bayonet and screw-in base options available ...GarySP — 11:31 AM
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
Tim, nice write up and thanks for sharing !! Sincerely Richardradiorich — 02:47 AM
Well, this was a real "Hum-Dinger" :lol: ! This will be kinda long, but hopefully it will help others having t...TV MAN — 01:55 AM
Shadow Meter Bulb
Philco 41-608 changer coupler
12' Philco
There are currently 5226 online users. [Complete List]
» 1 Member(s) | 5225 Guest(s)
