Model 20 speaker rebuild
Hello all,
I've been looking all over the place and I can't seem to find any data on the inductance value for the field coil in the speaker. I have an RLC bridge but according to my ohm meter, the winding is no longer continuous. The speaker itself is beyond repair. I want to replace it but I need the inductance value for an equivalent value choke.
Thanks to all who can help!
Mike
Hi and welcome to the Phourm!
Don't know if I've ever seen the inductance measurement listed for a field coil. It should be but the norm is resistance. The resistance is important as it will determine the voltage drop a cross the coil. This can be critical if the field coil is in the negative leg of the power supply because it will determine the amount of bias voltage the power supply will develop. The model 20 it's in the positive leg.
Noting the size of the filters I'd take a guess and say between 5 and 10 Henries. Don't think it is really critical.
Hi,
Using a BK Precision Model 875A LCR meter - it reads 3540 ohms resistance and 37.4 henrys inductance when connected at the plug for a Philco Model 20 speaker at the field coil connections. It has read pretty close on choke coils that I have measured that had a published value.
Tom
Hi Arran ,  Thanks for your help with this radio.And especial thanks for letting me know to look it up under United Ame...Antipodal — 04:32 AM
Philco 60 Squealing
Usually a wave trap is for keeping IF signals from entering the antenna and from leaving the antenna. You feed an IF sig...RodB — 09:30 PM
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
