New Project: 1934 Colonial 662 (corrected model)
Threads: 46
City: Menlo Park
State, Province, Country: CA
Lots of work on this set this weekend. First off, to diagnose the oscillator problem. I replaced all the paper caps, and the suspect 50k resistor, and the paper caps. Still no stations, and now there was an LF instability in the whole set as soon as the tuning cap was more than half open, with the set blowing raspberries from the speaker. At the end of the day, I returned to checking wiring and component values from the schematic, and found a broken wire from the converter tube grid circuit to the oscillator section of the tuning cap. OK, something to go on, and a good end to the day.
Today I removed the tuning cap, which was needed anyway, to replace the rubber bushings. I punched these out of some silicone foam, and added new wires to the cap #28 enameled wire, with cloth insulation slipped over it was a close match to the original. With this, I finally had some reception, but still a very unstable receiver. Whistles on stations up to about 100 on the dial, after that raspberries from the speaker, on either band. Eventually I tracked this to a bad solder joint connecting one of my restuffed caps. With that restored, I was able to align the radio and it really pulls in stations.
Pics tomorrow,
Ed
Threads: 46
City: Menlo Park
A few pics
Fine wires leading to the tuning capacitor stators. Notice the osc section on the left has a broken connection. These had so little spare that the breakage was probably due to the additional movement due to the perished rubber mounting grommets:
New grommets cur from silicone foam rubber:
Tuning cap with new wiring, ready for reinstallation.
Playing some music
Threads: 11
City: Greenlawn
State, Province, Country: NY
Nice and clean! Looks GR8!!
Threads: 46
City: Menlo Park
This weekend. I found time to restuff the two electrolytic cans. All is still working nicely. The chassis is waiting for a new line cord, still to be delivered, and will get new antenna and earth leads before returning to the cabinet.
Ed
Threads: 275
City: Wilsonville
State, Province, Country: OR
Looking great!
Threads: 46
City: Menlo Park
Another one over the finish line. I'm pleased with it and particularly enjoyed working on this radio for some reason I cannot quire explain.
Threads: 574
Cute set.
Threads: 129
City: Omak
State, Province, Country: WA
Hello Ed,
Nice little set !
Threads: 32
City: Wellborn Florida
Great job! Ed
Threads: 46
City: Menlo Park
Thanks everyone. I appreciate the kind words.
Threads: 425
City: Boston
She is a beaut. Nice size, maybe I could sneak one that in unoticed!
I think Colonial made a lot of stuff for SEARS if its the same Colonial I am familiar with.
Enjoy.
Paul B
Threads: 129
City: Omak
Hello Paul,
Yes it is the same company and I own a bunch of sears radios made by them also Arvin .
Threads: 425
City: Boston
I like that mantle style, thanks for confirming Rich.
Hi OSanders,
Look carefully at the band switch. Turn it slowly and "wiggle" it around the desired band. ...MrFixr55 — 12:33 AM |
5U4 vs 5Z4 tubes
I think that RCA and GE introduced metal tubes in the USA in 1936. I don't know if they were being made by RCA, GE or b...MrFixr55 — 11:20 PM |
Vlad95,
Thank you for the stringing guides and wow there are so manyosanders0311 — 06:01 PM |
5U4 vs 5Z4 tubes
A pre war Hallicrafters, and an early one too, very nice! 1936 is pretty early for metal tubes too, which would explain ...Arran — 05:58 PM |
Thanks Rod,
"When you hear the background hiss and no station it usually indicates that the oscillator quit" ...osanders0311 — 05:52 PM |
RodB
:beerchug:Vlad95 — 10:22 AM |
Vlad, you nailed it. Swiss and German roots.RodB — 09:54 AM |
5U4 vs 5Z4 tubes
Well this is a Hallicrafters SX/9 circa 1936.
No real issues so far although I dodged a real bullet with a cap that was...bridkarl — 07:59 AM |
5U4 vs 5Z4 tubes
The pinout is the same but the 5U4 has a 3 amp filament, verses 2 amps or less on the 5Z4. I think that the pinout of a ...Arran — 12:04 AM |
By the way.
osanders0311
Take a look here: Dial cord stringing Guides
May be here you can fount correct string settin...Vlad95 — 11:15 PM |
There are currently 1249 online users. [Complete List] » 1 Member(s) | 1248 Guest(s)
