38-10 Escutcheon
I have just begun restoration of a 38-10T and have been very impressed with the information that is on this site. This is my first PHILCO, after several Zeniths and various German sets. So, I’m looking forward to the 38-10 work, but would appreciate any pointers as to how to remove the escutcheon on the front of the dial glass. Part of it is slightly raised along one edge, but I can’t seem to get it to budge.
The cosmetic shape of the cabinet is pretty good on the top and sides, but unfortunately someone has previously tried to refinish the front, thereby removing the burl walnut photo finish. So, some creative work is needed later on.
Anyway, any pointers to get the escutcheon off without damaging it?
Thanks!
Welcome to the Phorum! I'm not familiar with that escutcheon, but someone will have the answers you need. Take care and BE HEALTHY! Gary
I believe you simply twist the outer trim ring counterclockwise to remove it.
https://www.philcoradio.com/phorum/showt...7#pid10757
Finally got it off. Thanks for the previous replies.  Yes, it did twist off, but one of the four locking tabs on the trim ring was bent and caused the assembly to lock up.
Greg
Icon_thumbup
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
My Philco 37-116 Restore
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
There are currently 1654 online users. [Complete List]
» 1 Member(s) | 1653 Guest(s)
