Philco model 511
Gentlemen and Radio Techs,
I have model 511 Philco I need the information on the cap block on and I need to know which way the electrolytic caps are layed out. I mean which way the plus and minus ends of the cap block go. And also there is a 13k resistor located in the power section that is not mentioned in the schematic. I am sending a picture of the bottom set.
As you can see if you look at the far right in the power section you will see a resistor that is black and blue and I found out that the Philco pre RMA code of that part is 13k.
Is this a late addtion or what? And how are the BC resistor taps are layed out as well?
If anyone can give some aid on this problem that would be helpful.
You can get the entire 38-page Installation and service manual thru my Schematic Info page on my site.
Also has technical info, schematic, parts listings, etc.
Manual also covers models 512, 513, 514, 515.
Regards,
Chuck
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
There are currently 764 online users. [Complete List]
» 1 Member(s) | 763 Guest(s)
