Model 20 Cathode Bias Resistor Value
Hey folks, need some help please.
Working on an unmodified model 20 (all except the power switch that someone changed).  And resistor 12…
For R12, detector cathode bias resistor, the schematics found on Philcoradio site for model 20 show this to be 50K.  Service Bulletin 36, table 3 lists resistor 12 as 50K also.  Someone replaced it with a 1K resistor.  It is the only non-dog-bone in the unit.  I have a 2nd model 20 that was modified but it has a 50K dog bone resistor in this spot.
Then to confuse me more, I looked in the Radio-Troubleshooter’s-Handbook (I like to look at the case-histories on models I am working on).  In RTH for model 20 it referenced checking the detector tube cathode bias resistor to ensure it is a 200 ohm, 2W resistor and isn’t open.
How can I determine if there was some change done to reduce this resistor value from 50K down to the 1K installed or to the 200 ohm noted in the RTH?  Anyone run across this and have any insight?  I can replace it with a 50K and see what happens or leave the 1K.  (I’m still preparing for re-cap, I discovered this during all my initial checks prior to power on)
George
George - Berthoud, Colorado.  Learned tube receiver repair and troubleshooting in the Navy way back when, came back around to it as an old guy.  Re-learning all I can.  Doing my part to restore a few of these old gems.
It would help to show photographs.
The resistor, as i remember, is 50K.
Maybe they referred to the part of the dual volume pot, which is also a cathode bias, which is 250 Ohm.
Attached is a pic of the resistor installed. Brown-black-red, assuming 1K?
Also attached is a pic from the RTH page, note 7.
Hope that helps. Thanks for the support.
George
Link to some info that might bring back memories.   https://philcoradio.com/phorum/showthrea...#pid177816
The resistor in spot 12 is marked as 1K and measures 1.2K. But schematic says 50K. I can easily replace it, just wondered if anyone knows of a reason it would have this value, particularly with the notes in the RTH. Thanks.
As you could see, the resistor there is Orange, and the document will say "12     50,000     Orange"
Good deal, thanks @morzh. I’ll replace it with a 50K. Appreciate all the input.
George
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
There are currently 718 online users. [Complete List]
» 1 Member(s) | 717 Guest(s)
