Help to identify Philco Radio located in Australia
Hi
Is there anyone that can help me identify this Philco radio eg particular model, date of manufacture. My mother has it but it originally belonged to my grandmother. I'm thinking from the 30s or 40s.
It's not in working order or at least I would never attempt to plug it in.
Sorry, I thought I had a full photo of the front and will take a photo when I can.
Any information would be greatly appreciated.
Thank you.
The power transformer has a built in switch to change the input voltage. In the 1950s WA had a line voltage of 260 volts AC at 50 HZ, Victoria 230 volts AC at 50 HZ. The set may have been made in the UK or Canada. The dial is not something from the USA with the stations listed by territories. The cabinet being local will be hard to match with pictures in the gallery. Hope you have the tubes or a list. If possible a picture of the speaker back. Please send a 6 pack of Coopers Pale Ale to who ever can ID the set. David
Many thanks for your reply David.
I'll post some more pictures when I can.
Cheers
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
