Threads: 4
City: Manhattan
State, Province, Country: NY
(This post was last modified: 06-19-2024, 03:06 AM by
TomasTomas.)
Typically one is GND, one is balanced (2 wires) and one is unbalanced (single ended).
Threads: 4
City: Manhattan
That information doesn't address my problem as the connections are not marked, and as stated I have seen different combinations hookups on the net. They all can't be correct. Just need to know what antenna wires go to which screw.
Threads: 270
Your set the screw terminals connect only to the loop ants barring the one test point. You need the external ant adapter. It plugs into the socket above the terminal strip. It has a connection for a single wire ant.
Now I think I've got it!
Threads: 4
City: Manhattan
Pulls in stations, so no additional ant required. Just need correct wire hookup sequence.
Thx
