Model 41-295 rectifier tube 5Z3 vs 80
Restoring a 41-295.  Every schematic I've seen has an 80 rectifier tube and the electrolytics in the pi filter are 18uF and 25uF.  However, the specimen I have has a 5Z3 rectifier tube and the filter electrolytics are 30uF and 12uF, which appear to be the original caps.  Is this a legitimate variation, or should I go back to the 80 tube to help preserve the transformer?  And any recommendations on which set of electrolytic filter caps to use?
If the 5Z3 and filters look original, I'd say stay with those components and values.The discrepancy may be the result of a production line change. The other possibility is difference between console and table versions of the chassis.
I would the 80 less strain on power transformer
The 80 and 5Z3 are both full-wave rectifiers, and interchangable. The difference is the current draw and output. The 5Z3 is the 80 on steroids, but at a price. The 80 draws 2.0 amps to the heater, and the 5Z3 draws 5.0 amps. Considering that the transformer is already dealing with the higher line voltages today from when built do you really want to push the issue by using a 5Z3? If the schematics say 80, I, like Vinser above, would use the 80. Take care and BE HEALTHY! Gary
Predicta Repairs Locally in So. Cal.?
Considerable TV data is stored on World Radio History. ChasChas — 03:33 PM
The 80 and 5Z3 are both full-wave rectifiers, and interchangable. The difference is the current draw and output. The 5...GarySP — 11:15 AM
Philco 37-116 toner
I will say i have sprayed over the Maguire's with no problem so there must not be any silicones etc in it Billpoulsbobill — 10:29 AM
I would the 80 less strain on power transformervinzer — 10:02 AM
Saddly, a lot of the techs knowledgable on these older sets are passing away, having health issues and simply aging. The...TV MAN — 08:42 AM
Thanks everyone for your responses and links to articles and products. A lot to ponder here. It will probably be a few w...462ron — 07:54 AM
If the 5Z3 and filters look original, I'd say stay with those components and values.The discrepancy may be the result of...Brad Winder — 06:47 AM
Restoring a 41-295.  Every schematic I've seen has an 80 rectifier tube and the electrolytics in the pi filter are 18uF ...FredM — 04:30 AM
Philco 37-116 toner
This may be irrelevant for different wood finishes from even longer ago, but maybe useful to research. Back in 1988 a...murrayatuptown — 01:53 AM
Philco 37-116 toner
When I refinished my 38-690, I used Mowhawk Polybuff to rub out the lacquer. I finished it with OZ cream polish. Not...tbone — 06:58 PM
There are currently 3527 online users. [Complete List]
» 1 Member(s) | 3526 Guest(s)
