RCA WV-98c
#31
strange. It should have more even to the GND, and the GND is 1M to the case.
#32
Are you saying if I measure ohms from the ground lead to case it should be 1m ohms? That low resistance tells me there is a leak to ground, right?
#33
Well, in the sch you provided (there is something missing at the very bottom, but I think it is GND), the sole connection to the case shown is the 1M resistor R31, which is used to bring the case and the GND under the same potential.
Unless I am missing something.
Of course there is a cap across that R31. And it could be bad. Or, again, we are missing something.
#34
I guess I need to look at r31 and C7.
That too.
There might be other things.
#36
Interesting readings, r31 common ground to case bounced to 1meg on analog meter, r31 common to case bounced to 1meg. R31=1meg.  Across c7, which is common to case with a parallel resistor = 40k ohms steady.
#37
My resistance readings are not even close. Worried about pins 1 and 6. Even though they are off, the meter works on dc 50v and higher.
#38
Would you re-read and correct?
This does not make sense.
#39
Check all your caps. Even ceramics. I am not sure what is going on.
#40
Just occurred to me: what if you have a power transformer leak? From a, say, secondary to the case. If it is bolted to teh case.
Not sure how to better check it.
#41
Thats a good thought but the secondary does go to ground via R30 27k resistor.
#42
Yes.....it would connect GND to case, and you do have 1MOhm.....
I am not sure how the wiper has resistance to the case.
#43
From now on iam using an analog meter. R31 removed is 1 meg and c7 .01 but chassis to common is 600k. Why is that?
#44
Are you saying the Chassis to GND became LESS when you removed the R31?
And we are sure the C7 and other caps are not leaking?
#45
Yep, hunting down the source. Will get back to you. Thanks
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
There are currently 777 online users. [Complete List]
» 2 Member(s) | 775 Guest(s)
