Threads: 46
City: Roseville, MN
Levi, the IF frequency has nothing to do with the tuning capacitor. I don't believe replacing the grommets on the tuning capacitor would change the oscillator frequency to the point of non operation. The oscillator frequency is mixed with the radio station frequency to produce the IF frequency. Then that signal is passed through the IF stage. So, the IF stage is still tuned to the IF frequency regardless of the tuning capacitor. When the tuning capacitor is removed then reinstalled there may be a slight change in oscillator frequency which would result in a respective shift in the position of the station on the dial. If you're not receiving any signals at all, I would suspect the oscillator is not running at all. BTW, try 355 kHz on your signal generator with the power turned up. If you get a tone then it points to an oscillator problem.
Threads: 34
City: Elkhart
could a bad oscillator tube cause the problems I'm having? I'm asking because I know the original Rectifier tube (an 80) was shorted so it wasn't allowing the radio to power up at all, so I wonder if the oscillator tube is bad as well? I hadn't had a chance to test every single tube inside the radio yet.
Threads: 50
City: Shenandoah,
Levi, when I suggested temporarily tacking a small cap on your tuning capacitor to lower the frequency to 177.5KC, I was referring to the tuning capacitor in your signal generator, not the one in your radio. Since you stated your generator doesn’t go below 300KC, doing as I suggested might get you where you need to be. Sorry I wasn’t more clear on my previous post!
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 46
City: Roseville, MN
If, after replacing the 80 tube, the B+ voltages are good. Then you can move on to troubleshoot the receiver. Maybe check the audio section first, inject a signal at the ungrounded end of the volume control.
Threads: 34
City: Elkhart
Well I think I figured out what the problem is, it was a bad 58 Tube in the front-end section (the 1st Detector tube), and I figured out that it was one of the 58 tubes that was bad (and specifically the 1st Detector tube) because when I put my hand over the grid cap of the 1st Detector tube the radio came in loud and clear but as soon as I removed my hand the radio went silent. So now I need to locate a NOS 58 Tube for the radio and I think that should get it going again.
Threads: 34
City: Elkhart
OK, well a little update on this radio, I was able to locate some replacement tubes for this radio and I popped them into the radio and its still acting much the same as it did before, Its pulling in stations but I have to have the volume turned clear up to even hear anything, and I'm starting to think I might have a bad antenna coil because no matter what I hook up to the antenna lead on this radio nothing seems to affect the radio's reception, the radio will pick up signals from my signal generator by hooking the signal generator through the grid cap of the 1st Detector Tube but going through the antenna lead doesn't seem to do anything. I had to do a partial replacement of the Antenna wire lead because the original wire lead for the antenna was broken through the insulation and had some wire exposed right around where the antenna wire exited the chassis. Also would an out of alignment IF cause the radio to not pick up much in the way of stations and cause the stations that do come in to hardly be audible? I'm asking because even though the IF alignment capacitor covers on the chassis were still intact and appear to of not been fiddled with in the past doesn't preclude the idea that someone didn't mess with them in the past but probably put the covers back on the IF Alignment capacitor holes so that the radio would be complete.
Threads: 34
City: Elkhart
Well it turns out in the past I did have a signal generator that was capable of going down to 177.5 KC but unfortunately I made the mistake of trading it with a friend of mine at a local computer store in town for a Hewlett-Packard HP8640B Signal Generator from 1972 that I didn't realize wasn't capable of going down below 455 KC without some serious modifications that are a little over my paygrade to do, and the signal generator I had that was capable of going down to 177.5 was a Heathkit Model SG-8 Signal Generator that had a range of 160 KC to 220 MC and I had already made the modifications on it so that it could use BNC connectors rather than the old Switchcraft style Microphone connectors that came with it originally, unfortunately the computer shop that the guy I traded my old Heathkit Signal Generator to is in the middle of moving to a new location and they have no phone number to get a hold of them at currently so I'm kind of stuck right now on this radio because as I stated in my previous post, I think the IF Alignment is way off on this radio and needs a realignment and unfortunately the only signal generator I have right now that has a physical tuning capacitor in it that I could do the "tack a capacitor across the tuning capacitor" modification to is a unit that has the old style Switchcraft style Microphone jacks on it and I don't have the proper RCA to BNC adaptor jack to make it so I can hook it up to my frequency counter I have (I used to but it somehow got lost when I was moving from my old apartment to my new house.) There are a ton of Heathkit Signal Generators for sale on ePay but the cheapest one on there is $50+$20 for shipping, and its being sold as a "Parts Only" unit.
Threads: 34
City: Elkhart
How Common is it for the Antenna Coil or Oscillator Coil on these Radios to fail? I'm asking because when I inject a signal from my signal generator into my radio at the point of the grid cap of the 58 tube for the 1st Detector Stage of the radio, I get full blast Audio from my signal Generator but if I inject a signal from my Signal Generator at the Antenna Lead-in Wire for the radio, I get nothing but a very faint audio signal even with the volume turned up full blast on the radio and the signal generator outputting full blast.
I would like to get this radio going but if its got a bad antenna coil then I may not be able to save this radio.
What's weird is that other than a lot of dirt buildup on the top of the chassis from sitting in someone's basement over the years or something, the chassis on this radio has absolutely no rust or other corrosion on it to speak of, and the chassis underneath was just as clean, so I'm really kind of stumped as to why this radio would be acting up like it is, because it seems like it should of been a simple replace the original capacitors and go kind of situation with this radio but so far that hasn't been the case.
Threads: 32
City: Wellborn Florida
Part of the fun of working on old radios. No body in 1930-1939 would think that a radio would be working 50+ years later. One thing that was done was to mix a little sulfur in the wax when making coils.
Threads: 11
City: Greenlawn
State, Province, Country: NY
Ohm the coil. If the primary is out, it could be that it took a lightning hit. You might be able to replace the antenna coil with a loop antenna from an AA5. You stated that touching the grid cap of the first detector gives you a good signal. What happens if you touch the grid cap of the RF Amp tube? If no signal and the tube is good, the primary of the interconnect transformer between the RF and 1st detector could be bad, likely an open primary.
Threads: 50
City: Shenandoah,
Maybe a universal type replacement antenna coil would work for you?
https://antiqueradiosandparts.com/index....y&path=393
Ron
AK 35 Philco 46-350
Threads: 34
City: Elkhart
UPDATE: I was able to pick up a signal generator on the cheap (amazingly enough) on feebay and I did an IF alignment following the instructions in the Riders manual as best as I could (I didn't use an "output meter" because I wasn't sure where to attach the probes of my VTVM to get the "Output Meter" to do what the Riders was saying it was supposed to do, so I just did it by ear, and Riders didn't say where to attach it at), and I can get the radio to receive stations above 900 kC just fine but below 900 kC and the tuner is practically dead and I know its not anything to do with the antenna coil because other wise it would be completely dead, and not half dead, and also this radio seems to only have RF, and Antenna Adjustments for the upper portion of the tuning dial and nothing for the lower portion of the tuning dial like most radios have.
As far as the IF alignment went the Primary IF alignment was fairly spot on, but the Secondary IF alignment was way off which kind of threw the Primary IF Alignment off a little bit, but that really didn't bring back the lower half of the tuner dial.
Also another strange thing it does is that when I put my hand over the 1st Detector Tube's Grid Cap the radio gets really loud like its supposed to sound but when I remove my hand from the 1st Detector Tube's Grid Cap the radio is barely audible with exception of one local station that comes in really loud no matter what and then there's another local station that that is barely audible on the radio unless I put my hand over the 1st detector tube grid cap, the only thing I can think of is that the 1st detector tube might be bad but I was given a couple of tubes by a fellow radio hobbyist locally that he said supposedly tested good and I was able to confirm that myself but that of course doesn't mean anything though in the world of tubes because I know from experience that some tubes can test good but perform horribly and some tubes can test horribly and perform really well when it comes to used tubes. Also it seems that I'm getting some "ghosting" on the radio dial, some of the stations that show up on the upper band is showing up on the middle of the bandspread (for example one of the local stations is at the frquency of 1340 kC and it shows up again at around 900 kC and the other station that I get in locally is ar 1270 kC and its showing up again on the dial around 960 kC (which there is supposed to be a station there locally but its not that station.) So something is definitely wrong with this radio yet and also when I try to make adjustments to the RF and Antenna Adjustments on the Tuning Capacitor they don't seem to do much except on the stronger stations and even then they don't seem to stay at the same adjustment you adjusted it to, and also the adjustments seem to be not consistent across the dial.
Any ideas as to what could be going on?
Threads: 34
City: Elkhart
Another Update: I found a couple of damaged coils inside this radio that might have something to do with why this radio is not working right, one of the coils that was damaged was the SW Detector Coil and that coil had a small break in the wire due to some corrosion and the break was towards the end of the coil which if I knew how to make that kind of fine repair it would of been a pretty easy repair, but I really don't know how to repair that fine of wire, the other broken coil was the Antenna Coil, which has one of the terminals broken from the cardboard form and it doesn't look like it has a wire coming from one of the windings on the coil missing from it, but if it did that might explain why the antenna lead-in wire doesn't seem to do much for the radio reception wise and also might explain why the radio is partially deaf but the SW Detector coil having a broken wire wouldn't seem like it would affect the AM Band at all I wouldn't think just the SW Band.
Threads: 50
City: Shenandoah,
Hi Levi, here’s just a thought. Most radios run the oscillator higher than the dial setting. Say you set your radio to 1000khz on the dial, then your oscillator would be running at 1000khz + the IF frequency of 177.5khz or 1177.5 kHz in this case. If your oscillator erroneously got tuned lower than the dial setting instead of the usual higher value, that could explain you getting your local stations far from where they should be on the dial. The easiest and quickest way to check your radio is by using a portable held near the one you’re working on and see if you can pickup what frequency the radio is running at. If you set the radio dial to 1000khz you should be able to pickup the oscillator on the portable around 1177.5 to confirm its running where it needs to be! Something that’s quick and easy to do!
Ron
AK 35 Philco 46-350
Threads: 54
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "J" hook or loop, make a splice, and solder the remaining coil wire to it in the hook, and reattach the other end of the new copper strand to the terminal. You could really use anything for this, such as 20 or 22 gauge solid wire, within reason, as it's easier to work with. If you don't have steady hands, or eyes, find someone who does. Antenna coils are pretty forgiving, you can often unwind six inches or more off of them to re-attach the coil to a terminal, and it doesn't detune them, though if the end that is buried under the coil this is where splicing on a pigtail comes in. Some really brave people actually rewind damaged coils, or even output transformers, but there are maths involved unless you can measure how many feet of wire was used on the original.
I don't think that sulfur in the wax is the issue, at least not in Philco sets, the problem there was nitrate based celluloid used as an insulator, the nitric acid leaches out sometimes and corrodes the wire, usually on the primaries of RF coils, though the police band coils in model 60s suffer from this as well, the secondaries are usually fine, and for some reason are on the coil form itself.
(This post was last modified: 02-13-2025, 08:51 PM by Arran.)
Philco 48-1201 cartridge
I need to give them a shout I suppose. I'm completely green when it comes to phonographs and cartridges. I re-capped the...KI5OMM — 08:43 PM |
Does have any?
Kirk Luffman (OldRestorer) used to make replacements, but I am not sure he eiteyr makes them or have s...morzh — 05:54 PM |
Hey folks. I'm finishing up restoring a Philco "Bing Crosby" 48-1201 and I need to replace the phono cartridge...KI5OMM — 02:50 PM |
Seeking 40-508 tube layout diagram
Thanks for the responses! I have the wiring schematics, but the problem I'm having is someone had clearly gave up an att...fluffygryphon — 02:35 PM |
The tube layout is available in our Library located at the bottom of the Home page.
Take care, - GaryGarySP — 02:20 PM |
Schematics.
No tube layout, but that could be figured out.morzh — 02:13 PM |
I am restoring a philco chippendale radiobar that is in extreme disrepair and I need to be able to make heads of tails o...fluffygryphon — 01:58 PM |
That's enough for me. I may not have completed that sale. Electronics nuts may appear very fishy to law enforcement. Whe...Paul Philco322 — 09:48 AM |
I bought my McIntosh amp on Kijiji. Went to cross the border to pick it up and pay.
(cross of our Rte 87 to yo...morzh — 07:23 AM |
Ok. Everything opens with a direct link. Yes. As Arran said, this is a transistor radio. It is a more expensive version ...RadioSvit — 03:07 PM |
There are currently 756 online users. [Complete List] » 3 Member(s) | 753 Guest(s)
