1950 Philco Model 123 AM Radio, Antenna Terminal
Threads: 2
City: Lake Jackson
State, Province, Country: Texas
Is there a best way to use the single-screw terminal on the back of this 1950 Philco? (best antenna type, possible grounding needs, etc.). I have restored and aligned it, and works great with the loop. Any input is very appreciated.
Mark
Threads: 16
City: Tulsa
Good afternoon! Could you possibly attach a photo to show us the connector? Could you also verify the model number? 123 doesn’t sound right. It’ll probably be 50-xxx.
Joseph
Philco 46-480
Philco 49-906
(This post was last modified: 12-30-2024, 06:11 PM by jrblasde.)
Threads: 32
City: Wellborn Florida
Not a Philco but common during that time frame page 2 ant hookup. David https://philcoradio.com/phorum/showthrea...7#pid90017
Threads: 45
City: Roseville, MN
Threads: 2
City: Lake Jackson
Thanks all. Sorry about the model #. It is a 50-922, and yes, run # 123.
Threads: 2
City: Lake Jackson
Not sure how to post a picture on this site. Any advice?
Threads: 2
City: Lake Jackson
the lead for the screw terminal connects with one of the leads going directly to the internal loop antenna. Once I find out how to post a pic, I will. Many thanks....and Happy New Year everyone.
Threads: 16
City: Tulsa
To add a photo, select the black New Reply button. Type your response, and below that there is a field to either drag and drop attachments or to click if you want to navigate to the file.
Joseph
Philco 46-480
Philco 49-906
Threads: 32
Some info from Beitmans.
Threads: 2
City: Lake Jackson
Threads: 2
City: Lake Jackson
Thanks everyone. hope the pics work. and thanks for the schematic. Mine has the 50C5 aud. output and 35Y4 rect.
Threads: 2
City: Lake Jackson
I have tried only a long wire on the external terminal. Get some overloading on strong stations actually using the wire, but weak ones are strengthened. This is during the daytime.
Mark
Threads: 45
City: Roseville, MN
Your antenna is working as intended. The loop antenna is an rf transformer with the connection available for an external wire antenna. The signal on that wire brings in a stronger signal resulting in more gain to the radio.
I am not sure how a transformer could be weak. It could be inadequate, but only when you replace the original with somet...morzh — 09:56 AM |
Good news everyone! I think I have found everything I need for rewinding the antenna coil primary.
I found some pla...Stormlord5500 — 09:40 AM |
Philco Battery-WWII vintage
My younger sister went to SUNY Plattsburg NY, (BS, MS, RN) in the late 1970sabout 10 min from the Northern NY / Canada b...MrFixr55 — 07:59 AM |
Hello Bob,
What Amazing find!
Sincerely Richardradiorich — 10:19 PM |
Hi Murf,
Do this:
Monitor between ground and one plate of the rectifier while playing the radio. Do the same with ...MrFixr55 — 09:51 PM |
Mike;
I take it that Soviet cars did not come equipped with block heaters, hence the hot oil change? Where I lived in...Arran — 08:42 PM |
The more the better. (Within reasonable limits.)
2-5 times more is no problem in this case.Vlad95 — 03:50 PM |
Thanks, RodB and Vlad95,
I was mainly trying to figure out this capacitor to locate a replacement, Vlad thank you for...osanders0311 — 03:44 PM |
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage?
murfmurf — 01:22 PM |
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM |
There are currently 629 online users. [Complete List] » 1 Member(s) | 628 Guest(s)
