Philco 16B restoration
I recently acquired this Philco 16B code 125. It has been worked on prior and I will need some assistance from the more learned members while I attempt to restore it.
When I was taking the chassis out to clean it up I noticed these two wires attached to the transformer attached to the speaker. I have no idea what the purpose of these two clamped wires would be. If someone could enlighten me as to why they were soldered here, it would be greatly appreciated. I am still a novice at radio repair.
That's an easy one. They're for an auxiliary battery (just kidding). Actually they would connect to a remote speaker. If you follow the wires under the speaker frame they are probably connected in parallel with the speaker voice coil. The voice coil and the purple wires are connected to the secondary winding of the output transformer.
Thanks very much Rod. Appreciate the prompt response.
My inexperience will show again in later posts as I start work in earnest on this radio. My repairs up until now have been on radios that had not undergone a lot of previous repairs.
I think someone simply try to use an extra speaker. No other reason.
Were there other kinds of capacitors in 1934 other than the old Wax Paper Capac...
I don't know about the caps used in this Stewart Warner, but with the ones used in RCA and G.E sets you can get the old ...Arran — 12:27 AM
OK, Interesting, I didn't realize these were used by other companies as well, I've only seen this style of caps in one o...captainclock1988 — 11:05 PM
Westinghouse H104
From the schematic, I think that the 2 6Y6s in this set are in parallel, not push-pull. Look at the output transformer....MrFixr55 — 10:41 PM
Let me see how much I can enlarge them. I had formatted this to plot on an E sized paper, but I do realize that the bloc...jrblasde — 10:36 PM
Predicta parts
"Hello, good afternoon, does anyone have the antenna, the top cover of the tuner and all the knobs from a '58 Philc...GarySP — 10:18 PM
Need Help Identifying an Old Zenith Radio Model I used to Have when I was a kid
There are many common reasons for a radio to not play but the phono section to work.  For a transformer powered set, any...MrFixr55 — 10:12 PM
A suggestion: increase sizes of yuor passives. They are not well-readable. Lool at the right upper part of the section ...morzh — 10:09 PM
Hi Captain Clock, RCA used caps like these in some of their radios. I have 2 RCA Farm sets ca 1936 that used caps l...MrFixr55 — 09:40 PM
Hi Joseph, I understand that you want to get all of the bugs out of the schematic before printing the last version. ...MrFixr55 — 09:27 PM
Were there other kinds of capacitors in 1934 other than the old Wax Paper Capaci...
Hello everyone, I was replacing the original capacitors from my 1934 Stewart-Warner Tombstone Radio the other day and I ...captainclock1988 — 09:08 PM
There are currently 2784 online users. [Complete List]
» 1 Member(s) | 2783 Guest(s)
