Help with schematic
Having trouble reading this schematic. EMC 300 meter and the ac does not work.
What part are you having trouble reading?
The dc+ is void for 3v scale. Thats what thru me off. Also you need the batteries for the ac operation.
AC is perfect....
1. DC+ is off, 2.9vdc may measure 5vdc but its off on a curve so 4vdc goes full scale on 10v scale
2. DC- is backwards. Meter sets ok or full right but on negative voltage it tries to keep going right vs coming back down. Switching the leeds , the measurement is off.
3. Ohms wont go to standing full scale. There is no ohms adjust just zero adjust and it does nothing.
Have you checked the 117L7 tube with a quality tube tester? Do you have a known good 117L7 that you can substitute? Have you looked at the chassis for signs of repairs which may have been done incorrectly? Have you replaced the wax-paper and electrolytic capacitors?
All good spots to start with. I would include cleaning all contact switches with the proper DeOxit. Start with the easy and inexpensive and move up as needs require. Take care and BE HEALTHY! Gary
Cleaned the switches and replaced a broken 9ohm resistor. Dc+ volts still pegs meter full left. 117l7 is perfect. Since this meter does not have bridge circuit, what balances out the meter?
I tried to trace the dc+ but got lost.
Philco 16B restoration
This is fairly common when two components near each other are to be connected to the same point. Saves wire space on ter...RodB — 09:16 PM
Yes, Philco did this twisting parts and, no, that does not affect anything. Just a way to connect parts.morzh — 08:53 PM
I need some advice on the two enclosed photos. The first shows a 8k resistor, part #42 and a 2 meg resistor, part #41. T...Phil27 — 07:24 PM
Restoring Philco 96
This chassis is strange. Yes, it obviously has some repairs done to it. But many resistors, that seem factory, or at l...morzh — 05:57 PM
37-640 bandswitch ?
Thanks Greg, I think things may work out.  I will update as I start the work again when the 620 arrives---Johngeorgetownjohn — 04:36 PM
37-640 bandswitch ?
Oops, I for some reason I got it in to my head that you have 630, not a 640. None the less the front end of the 640/620 ...Greg — 03:40 PM
37-640 bandswitch ?
This is a correction from last post about tuner capacitor. The front of my 640 tuner bracket is factory stamped with 37...georgetownjohn — 02:57 PM
37-640 bandswitch ?
Thanks Greg, your reassurance of using parts from the 620 is very helpful.  Since I am still new at all this, I will wai...georgetownjohn — 02:53 PM
37-640 bandswitch ?
Replacing that one section of the band switch makes sense. Just make sure the two have the same connections, though I ca...Greg — 01:59 PM
37-640 bandswitch possible solution
Thanks for the info Greg.  I have bought a 37-620 non-working chassis in the hopes that I can use parts of the RF unit/b...georgetownjohn — 11:46 AM
There are currently 2309 online users. [Complete List]
» 3 Member(s) | 2306 Guest(s)
