Which rubber parts for Philco 37-640
Hello Phorum Membbers:   For the Philco 37-640 tombstone radio I am trying to restore, which  rubber gromets should I order for the chassis bottom to cabinet bottom(PHILCO chassis supports).  I believe that the mounting screws go through them.  Should I order CH32 or CH4 from Renovated Radios?  Thanks, John
Hello John,
Well Have you tried to measure the original one ?
Don't quote me but I believe it is CH4
Sincerely richard
Thanks Richard for the replay. Unfortunately, I had thrown the old pieces away but they were so distorted and smashed, I don't know if I could of even gotten a true measurement.--John
Philco 50-295 antenna connections
Shoot, just realized that the blue wire connecting to the top of the tuning cap can't go to terminal D since that's on t...keith49vj3 — 01:20 PM
I forgot to mention that the IF and audio stages for AM work and FM plays great. Really confused by the antenna set up....keith49vj3 — 01:16 PM
All, I picked up a Philco 50-295 for a couple of dollars so I could demo sweep alignments for folks in my radio club.  T...keith49vj3 — 01:14 PM
Hi Jeffcon, First off, Welcome to the Philco Phorum!, a Phamily Phriendly Phorum, Phull of Phine Phriendly Pholks and ...MrFixr55 — 07:53 AM
+1 on what Morzh and Rod said, do the caps first. I only supplied the type and replacement numbers because in your first...462ron — 07:26 AM
Philco 370LZ chair side not a 71LZ
I came across this post and I just redid my 370. My Question is: Where does the toner rod go. This one was in a bag a...Villager61 — 08:36 PM
My collection presentation
This will be a description of my twice favorite part of the collection. First, these are my favorite battery radios. S...Vlad95 — 06:25 PM
You probably don't have to worry about replacing transistors until you finish the recap. If you find that a transistor s...RodB — 10:19 AM
Start with recap. Address transistors only if needed. Testing transistors is simple and is best done with an analog ohmm...morzh — 09:01 AM
Hi Jeffcon, your HR-101 transistors cross reference over to an ECG-104 or RCA SK 3719 or an NTE104. It’s a PNP Ge (germa...462ron — 08:27 AM
There are currently 3259 online users. [Complete List]
» 1 Member(s) | 3258 Guest(s)
