Philco 91 Tuning Condenser
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't turn it very much. I have ordered a new one from Radio Daze so I am not concerned with destroying it. I'd like to take it totally apart so I can clean up the rust.
Dan
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.
I thought you meant the actual dial....there are rivets.
Nope it was the metal part. I got that off. In fact I took the whole thing apart. Pretty easy.
Yes, in those it is.
In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.
There are currently 1918 online users. [Complete List]
» 1 Member(s) | 1917 Guest(s)
