Philco 70 antenna lead
Seems odd to me that Philco would run the antenna lead over top of the filter caps and the power cord. Would that not induce unwanted noise? Has anyone noticed this and tried rerunning the wire along the chassis?
Jim
If you mean the wire going from the Volume pot to the back, here
https://cnj.craigslist.org/ele/d/tennent...98899.html
It does not seem to run ovefr those. Quite the other way.
(click to the phot of the chassis bottom).
In another chassis I see it crossing diagonally only over the power wire (not over the can), but this is at a right angle, so it is pretty insignificant.
I see in that picture that the power cord is held next to the chassis with the clip that in mine holds the antenna lead. Looks like the person who had this radio before me routed the antenna lead like that. I'll reroute the lead.
My wire runs the way yours does, Jim. From the antenna, to the clip under the right rear chassis mount, then to the volume control.
Dave
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have stuffed the original filter caps on top, it won't cause much of a problem. The main problem with these old radios of that era is the finely wound coils (such as the main antenna coil from that wire) has turned to basically mush (don't know exactly what they coated it with or soaked it in), cut one open and examine with a magno glass to see. Put a signal tracer on that front end and hear it, that sound is amplified thoughout the remaining stages and ruins it, the radio just won't filter it out and it sounds nothing like when it was new - that coupled with all the interference of todays meanies that hit it. You have to rewind these with fresh wire and start at the front end to get any sort of good fidelity, can you say get a coil winder? Then you can work your way from the front end to the final result. Turn the tone cap off and hear the awful sound, that is the mush I am speaking of, it should not sound that way. I have found some good sounds and decidedly bad sounds out of the 70. The IF coils suffer from this as well.
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and such.
The reason to failure would usually be the corrosion caused by the celluloid disintegration, but the wire was just that, wire, no mush.
I agree. From the ones I've worked on its always been that green corrosion that causes the coils to open.
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
Sounds good Gary I'll do that. I have plenty of stuff like that I can scrounge up. I am still kind of new to all this so...Stormlord5500 — 08:47 AM
Philco Battery-WWII vintage
Seems to me that this a general purpose or radio filament 6V battery of very high amp-hour capacity and very high "...MrFixr55 — 08:08 AM
You should be able to inject an audio signal such as from a CD or mP3into the radio at the volume control. The set will...MrFixr55 — 08:14 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
There are currently 515 online users. [Complete List]
» 1 Member(s) | 514 Guest(s)
