Claude
You can probably postpone your router purchase...Mark Oppat heard I needed a couple grille bars for my 38-116, and he's sending me a couple originals. So thank you anyway for your kind offer to reproduce these, but apparently the missing grille bar problem is already solved.
Threads: 14
City: Grand Blanc, Michigan
Bummer there goes my excuse for a new router.
Threads: 5
claude,
I'd buy the router now anyway, then your ready for the next radio that needs a repo grill bar
Threads: 30
City: Minneapolis/St. Paul MN
OK, going back to the original post in this thread, here's the before and after of the Philco 42-122 $5 farm radio.
[Image: http://i27.photobucket.com/albums/c170/p...-122ba.jpg]
I've edited in a smaller version - much better!
Bill
Sent from my Pentium II on the AT&T Dial Network
Bill - nice job! Please tell us how you were able to refinish the cabinet yet save those photofinish stripes on the front.
Threads: 30
Since the basic finish was pretty much intact, I took a soft cloth and dipped it in some walnut stain and wiped it over the front and sides. That took out most of the scratches.
As I originally described in the first post, the top was badly weather worn, as you can now tell. At first I stained the top, but it came out way too dark, so I took as much of the color off as I could with lacquer thinner and just finished it that way. You can still see a difference between the top and sides, bit I decided I could live with it that way.
Also, the left side veneer strip was half gone. Since I couldn't find any walnut veneer in a 3/4" wide roll, I used oak veneer and painted it brown. To match it to the rest of the cabinet, I also painted the other side and the bottom. Semi-gloss lacquer went over the whole cabinet to complete it.
The chassis was worse off than the cabinet, but the earlier posts in this thread described that process.
All told, for a $5 investment, and maybe another $10 in parts, not too bad!
Bill
Threads: 8
Ron,
What code is your 38-116? I just finished mine, and it was a code 121; the one with the older style RF deck with trimmers on the bottom. If you's is a code 121, could you see what type 'W' speaker it has? I'm still stumped why mine came with an output transformer that has a primary resistance that does not match the schematic while the code 125 transformer does match resistance wise.
Keep us posted on the progress. I think these are very interesting Philco consoles. A lot of them are around, they are a bit of a challenge to restore, but they are very good performers. Overall, they could be the bargain high end Philco for today's collector.
Frank.
Frank
I've started a new thread on the 38-116:
http://www.philcoradio.com/phorum/showthread.php?tid=78
I'll answer your post there.
Threads: 15
City: Ortonville, MI
Ah, such memories. Just before Christmas 1936, the Ned's Firestone store delivered a big cardboard box with that big Philco wreath on it. Couldn't touch it until father got home. He unpacked it, and there was a sparkling new Philco 37-650X. It replaced a United Reproducers "Currier"' set of about 1930 vintage. There was already a good antenna on the house and the Philco worked like a bomb on it. It seemed incredible how much reception this new set pulled in (after the old TRF job!). We had the set into the fifties. I maintained it all those years. One of the guys at work wanted it, as it had been replaced by something else, so I gave it to him (dumb, dumb!). But in recent years, I've acquired another one, and the table version of that model as well.
I perceive that the 37-650 was a big seller. It was a good balance between price and performance, so it may have been the bread-and-butter set for Philco that year.
12' Philco
If it is 12', either Kareem or Andre would have to jump pretty high to look at the front panel.
Kareem would have an e...morzh — 01:48 PM |
12' Philco
And here's a story about the tires on the truck. Same "no-stoop" guy must have installed these! Take care a...GarySP — 01:17 PM |
Hickok AC51 tube tester
I think they have only shown the secondaries of the transformer.
Two of them feed the rectifiers' filaments.morzh — 12:58 PM |
If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM |
12' Philco
Rod,
Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently.
H...morzh — 12:54 PM |
Absolutely no one is going to reverse engineer that circuit. Even the iron core is missing.RodB — 10:37 AM |
Thanks to both members for your help regarding wire and tuner mtg supports. regards--Johngeorgetownjohn — 09:33 AM |
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM |
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM |
My last cabinet for this year
Hello Dan,
That is really beautiful what great looking radio you have !
I have friends who live in Calgary and the wea...radiorich — 01:51 AM |
There are currently 5452 online users. [Complete List] » 3 Member(s) | 5449 Guest(s)
