Hello Joseph,
That looks great only thing I would make sure is that screw has good clean area where it contacts the ground lug.
Excellent point! Thank you, sir.
Joseph
Philco 46-480
Philco 49-906
Joseph,
Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps should be about half the diameter those in your picture, unless you kept the leads long.
I never had them protrude much at all.
In fact, in my article on this, I restuffed 0.01uF Y2 caps; you could see in the pictures they are quite inside.
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back in August, before I had learned that the Bakelite housing could be restuffed. These are X1Y1 rated, but I’ve since learned that I can use a lesser safety rating.
These are also 0.01 μF capacitors. Likely much larger than a 10 nF capacitor. Even so, I am surprised by their size.
Joseph
Philco 46-480
Philco 49-906
0.01uF and 10nF are the same capacitances Icon_lol
Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obviously that dictates smaller size.
Plus you will likely pay more for the caps with more stringent rating.
Y2 is quite enough.
Silly me, you are right! I read and wrote nF, but was thinking pF.
Joseph
Philco 46-480
Philco 49-906
Hello joseph,
Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0.
Anyway both Digi-Key and Mouser carry it.
far as Mouser if you buy 10 they are 24 cents each.
https://www.mouser.com/ProductDetail/Vis...iPhw%3D%3D
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know the secret!
Joseph
Philco 46-480
Philco 49-906
Thanks, everyone! I suppose I’ll keep these installed since I have them and they do fit. But moving forward I’ll know th...jrblasde — 07:57 AM
Hello joseph, Here is the one that I use made by Vishay part no. VY2103M59Y5VS63V0. Anyway both Digi-Key and Mouser ca...radiorich — 01:34 AM
Silly me, you are right! I read and wrote nF, but was thinking pF.jrblasde — 10:48 PM
0.01uF and 10nF are the same capacitances :lol: Its the rating. Yours are rated to 500V and the Y2 are up to 300V. Obvi...morzh — 10:41 PM
You’re right, yours are much smaller. I must admit that I ordered these without much regard to size. I ordered them back...jrblasde — 10:29 PM
What should I offer?
Thanks, that makes sense. I searched Hepplewhite on Google, and saw some fancy dining chairs.jrblasde — 10:23 PM
My memory had not failed me when I was writing about those inductances. I found them, both 5.6mH and 10mH, both small ax...morzh — 10:21 PM
Joseph, Yes you could do that too. But why did you choose to buy these conspicuously large capacitors? 10nF Y2 caps sho...morzh — 10:02 PM
Thomas Sheraton gave his name to the style. That is others in 19 century took his name and assigned it to the style. G...morzh — 09:59 PM
Excellent point! Thank you, sir.jrblasde — 09:58 PM
There are currently 3364 online users. [Complete List]
» 2 Member(s) | 3362 Guest(s)
