Philco 91 Restore Code ??
#46
Because the usable power rating of it then is (3,200/20,000)*25W= 4W.
Maybe a tad more due to the mass, but not much. You are not using the full resistor.
#47
I wondered about that. Wish there was some place local to get this stuff.
#48
The shadow meter in the radio is responding to tuned signals but it never goes to a very small shadow even on strong signals. Best I can get is about a 3/8 of an inch. Is that about right or should it get narrower? The 1k resistor (#14) has been replaced. Would altering the value of #14 make any difference if so higher or lower?
Also I can't get he lower end of the dial completely lined up. Off about 10kc. The low frequency compensator (#23) is turned out to where it is no longer making a difference. There is a 410pf mica (#24) across the compensator. Could that be a problem and maybe replace it with a different value. The dial is reading higher than the 10kc higher than it should. The high side is spot on.
Dan
#49
410pF is a large capacitance to parallel to a compensator.
As for the shadowmeter....yes, 3/8" is a bit wide, but then it also depends on the station's strength.
Does it go narrower than that when fed a signal from a generator?
#50
The width does not get narrower with generator.
I think I will try some other cap values.
#51
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet is a bit weak. Not the end of the world, not even that important: I tune by ear and the shadowgraph is for show and tell mostly.
#52
How do I know if AVC is OK?
For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I tried lower and higher values but lost gain with them. The original cap measured 296pf with my CCC meter. New Fluke 115 is on the way.
Philco 50-295 antenna connections
Thanks Rod, That makes perfect sense. Is there a way to edit my post? It's a Philco 50-925 and not a Philco 50-295. D...keith49vj3 — 09:55 PM
C is for an external speaker.RodB — 08:39 PM
Philco 370LZ chair side not a 71LZ
Can you send a couple of pictures?slford310 — 07:11 PM
Thank you for the reply. After much studying I figured it just sat there and you have to open the top and pull up and/o...Villager61 — 06:42 PM
Sorry, I haven't gotten to this project yet, so I don't have the answer, but I bet one of the experts on this site does....slford310 — 05:54 PM
Value of capacitor
That’s what I thought, but when I’m undoing 50 years of “repairs” it never hurts to check. Thanksbridkarl — 04:03 PM
Value of capacitor
According to AI, "Yes, you're reading that correctly. A .005 capacitor typically refers to 0.005 microfarads (µF), ...HowardWoodard — 03:57 PM
Value of capacitor
I’m having to replace this audio coupling cap between the plate of a 6F6 and a phone jack. The parts list just says .005...bridkarl — 03:45 PM
Shoot, just realized that the blue wire connecting to the top of the tuning cap can't go to terminal D since that's on t...keith49vj3 — 01:20 PM
I forgot to mention that the IF and audio stages for AM work and FM plays great. Really confused by the antenna set up....keith49vj3 — 01:16 PM
