National NC-57 case
I’m currently recapping this National NC/57. This has a scratch on the case. I guess I can sand this out and just do a small touchup.
Not only is the paint chipped out but it has dent that will need to be pushed, or pounded out. The set must have been dropped, and landed on the band switch knob, hopefully pushing the knob back, and denting the cabinet is the extent of the damage.
Yea. I think a repaint is order.
I probably have a spare bandswitch knob somewhere. Since this is an AA-5 type design I plan to drop a Triad x35 isolation transformer in this.
The other design element I want to change is add some connectors so you can easily remove the speaker. As I’m reading this the filter choke goes to the pins 3 and 4 of the 6V6 audio output tube.
Running two wires topside on the chassis will make that easier. At some point the speaker dies - that way it can be replaced without taking the chassis off.
I’m debating replacing the dials. Reproductions are available, but I’d have to get a rivet tool.
As far as the cabinet condition, try cleaning it with Goop (non-pumice) hand cleaner and 0000 steel wool. GENTLY! You'll be amazed how much dirt will come off. Wipe it down with soft rags. It will still have some battle scars, but a lot of the smudges should come off. At this point what is there to lose? - Gary
I have some of that so I’ll try it. That works great on my Philcos. This radio was a gift from a friend of mine so I’m trying to make
I’m trying to find if there’s a readily available grey paint that matches.
For that dent, if it's easy to get to both sides of the sheet metal place hardwood or metal shims on both sides of the dent then lock them together with C-clamps, or better still, a vise. It nay press the dent back out. Luckily there didn't seem to be any creases, just an indent. Let it sit overnight. Just like my last comment... At this point, what is there to lose. Take care and BE HEALTHY! Gary
It looks like it didn’t dent the metal. Using 0000 steel wool should clean up the front.
I’ve found this Winter Grey gloss paint. Not an exact match but it will work.
The labels are actually incised in the metal. So I’m thinking I can paint the case and then use a white lacquer stick on the letters.
Philco 370LZ chair side not a 71LZ
Can you send a couple of pictures?slford310 — 07:11 PM
Thank you for the reply. After much studying I figured it just sat there and you have to open the top and pull up and/o...Villager61 — 06:42 PM
Sorry, I haven't gotten to this project yet, so I don't have the answer, but I bet one of the experts on this site does....slford310 — 05:54 PM
Value of capacitor
That’s what I thought, but when I’m undoing 50 years of “repairs” it never hurts to check. Thanksbridkarl — 04:03 PM
Value of capacitor
According to AI, "Yes, you're reading that correctly. A .005 capacitor typically refers to 0.005 microfarads (µF), ...HowardWoodard — 03:57 PM
Value of capacitor
I’m having to replace this audio coupling cap between the plate of a 6F6 and a phone jack. The parts list just says .005...bridkarl — 03:45 PM
Philco 50-295 antenna connections
Shoot, just realized that the blue wire connecting to the top of the tuning cap can't go to terminal D since that's on t...keith49vj3 — 01:20 PM
I forgot to mention that the IF and audio stages for AM work and FM plays great. Really confused by the antenna set up....keith49vj3 — 01:16 PM
All, I picked up a Philco 50-295 for a couple of dollars so I could demo sweep alignments for folks in my radio club.  T...keith49vj3 — 01:14 PM
Hi Jeffcon, First off, Welcome to the Philco Phorum!, a Phamily Phriendly Phorum, Phull of Phine Phriendly Pholks and ...MrFixr55 — 07:53 AM
There are currently 2603 online users. [Complete List]
» 2 Member(s) | 2601 Guest(s)
