Threads: 437
City: Boston
[Image: https://mail.google.com/mail/u/0?ui=2&ik...5bc62c1&zw]I have been listening to this Stewart Warner this morning, a bit of an awkward looker but sounds great, my wife asked if it was FM it sounds so nice. It has a phase inversion circuit for the large speaker and I struggle to understand that concept at times but it sounds good. 6 tubes and Slug tuning, 1946 year of manufacture. It will be playing most of today. Paul B.
Your image does not show up.
A radio from 1946, they should've added the FM band.
Threads: 23
City: Greenlawn
State, Province, Country: NY
Hi Pholks,
Paul, what do you mean by phase invertor? These are usually used only with Push Pull output stages. I pulled up the Nostalgia Air schematic God bless them and the service that they provide to this hobby, but this schematic is particularly hard to see.
The circuit is rather normal except for using the 6SF7 as an IF and detector and the 6SK7 as a 1st Audio. However, My Zenith 6S52 chassis uses a 6K7 and 6F6 as an audio section and that set sounds particularly good. This set is an AM / SW set and does not have an FM circuit. However, it is inductively tuned, like a car radio of the 50s, 60s and 70s.
Threads: 437
City: Boston
I think I plead a bit confuzzled, in the Riders it states it uses a two stage type of inverse feedback arrangement........so my bad on phase inversion. So what do they mean with two stage inverse feedback arrangement?
Yeah I know no FM, wifes comment though is interesting as she can tell most sets are AM only don't always sound BIG. If she thinks it sounds like FM means I can play it more  .
Threads: 55
City: Roseville, MN
Paul,
Each stage of a radio inverts the signal 180 degrees from grid to plate and the signal at the cathode is in phase (but, quite often the cathode is at ground potential). So negative feedback can be used just about anywhere in the audio amplifier as long as the source is out of phase with the destination and is typically 2 or 3 stages. The effect is a slight reduction in volume and greatly reduces distortion. Just turn up the volume control a notch.
(This post was last modified: 03-23-2025, 12:28 PM by RodB.)
Threads: 437
City: Boston
Thanks for the explanation, perhaps the lower distortion is why this radio sounds so nice. The 6K6 is the output tube and seems to do the job. I put a Radio Shack AM tunable antenna behind the thing and it sings even on the low power AM stations I enjoy. I have another STewart Warner but it needs some work and is not the same build quality of this one. Stewart Warner made some Firestone branded sets. The 62T16 has a sister Firestone set.
Here is my other Stewart Warner, though it wears the Firestone Badge....
https://www.flickr.com/photos/92577012@N...ed-public/
You may detect on the left a smudgey appearance, the was a hole there and it was rudely plugged I someone planned a mod at some point. I like the dial glass though.
Threads: 55
City: Roseville, MN
I'm finishing up the restoration of a Firestone/Stewart Warner right now. I've had it several years and finished the cabinet work some time ago. It's a fair sounding radio and very sensitive.
Threads: 437
City: Boston
What Model do you have there RodB? Got a photo?
Threads: 437
City: Boston
Been listening to the little red one too. When a Philco Console is just too big.
[Image: https://ci3.googleusercontent.com/mail-i...=s0-l75-ft]
I've noticed that there was this trend towards neo-classical cabinets in that era, some look all right, but others don't do anything for me, like that Firestone Paul linked to. Then again some people don't like the Northern Electric 5200s:
https://www.radiomuseum.org/r/northernel_5200.html
But I like them for the same reason I like the Bush DAC-90 and DAC-90As, they are a nice, clean design, but still unique. I have two 5200s but need to overhaul the chassis. The main issue is that they put the dial lettering on the outside of that plastic window where it should be on the inside, so you have to be careful polishing them.
Threads: 55
City: Roseville, MN
Paul,
Here's a before photo, it's a Firestone S-7397-9. Would the S stand for Stewart Warner?
Threads: 23
City: Greenlawn
@PaulPhilco, if the Wife likes it, don't ask questions, just enjoy it!
I hafta look at the schematic again, I could not see the negative feedback path, at least not in the amp. I have a Crosley 5C2 which actually uses a "Positive feedback from plate of output via resistor to screen of the previous stage audio amp to increase bass response. it did work.
Threads: 437
City: Boston
Threads: 437
City: Boston
So I have images I post visible on myPC, not visible on my android, maybe post my photos different fashion. Paul
Threads: 55
City: Roseville, MN
Paul, yes the 9003-B is the same chassis in my Firestone. Oddly, the Woolerac 3-3A I have is also a variant of the Stewart Warner 9003B. And I acquired them both at the same time from the same person.
| Hello Everyone,
