My Philco 37-116 Restore
I have been doing some more checking on the chassis. I have found one of the chokes is not measuring as it is shown in the schematic. Part 120 is supposed to be 400 ohms but it is reading 3K. The part may not be original to the chassis as I see some sloppy soldering and cut wires that must have gone to the original one. I assume the 3K is going to cause a problem. Do I need to locate another one?
I also noticed ECaps 126 and 127 are 8MF wired in parallel. Can I just use one 16MF instead?
Mine was bad too.
I got a replacement off of ebay, a 32-7056N (not sure what the N means).
That's not the "same" part as the original is 32-7491.
However, I believe that if you look in parts catalogs for the specs you'll find they are the same.
The only "difference" is that leads exit differently.
One has both leads on one side and the other has them on opposite sides. (Don't recall which is which).
If you order one, be careful as I suspect it could be bad too.
I see two 32-7056 listed. One seems $$ and the other $$$.
Greg O.
Whitehall, PA
Hi Greg, Thanks for the info. I might be better off getting a new Hammond one. They are both the one on top of the chassis. I need the 32-7491 filter and it mounts under the chassis.
Dan
Yes on the caps... 1x16 will be just fine. In either case just make sure the voltage rating is >= to the specified.
I just paralleled some 630V film caps for some of the other e-caps in mine.
I used a 32-7056 in place of the 32-7491. It fits in the place of the original.
Greg O.
Whitehall, PA
Thanks Greg I was pretty sure it would be ok but you never know what the engineers are thinking.
Dan
Hello, I need to replace one of the grid wires coming out of the selector mechanism. I see 4 screws on the bottom of the cans, two on each side. If I take those screws out will I gain access to replace the grid wire? I'm worried there may be nuts under the screws.
Anyone know why the .004 paper cap (#74) is a 1000 volt cap. It is attached to the volume control.
Dan
Hi Dan,
Chances are that the 1000V cap is what they had available.
The cap in question couples the detector to the volume control. There is no B+ on that cap, and likely no more than about -20V or so AVC voltage and less than about -3V grid bias for the 1st audio amp. Most replacement mylar caps from suppliers to the hobby are rated for about 630V max. Non-electrolytic caps are rated for a maximum voltage. Fore a radio whose maximum B+ voltage is 250V, a 630V cap provides more protection from dielectric breakdown than a 400V cap.
However, electrolytics are rated in working voltage, so it is not good to use a 500 WV (Working Volt) cap in an AA5 radio whose rectifier generates about 150VDC. Maximum voltage tolerated by an electrolytic cap is not much higher than the working voltage, so take no-load voltage into consideration when picking electrolytic caps.
Exactly. It's just that they had limited variety of caps; it was much cheaper. What does it matter if the cap costs you pennies? so you put a 1kV cap where 50V would suffice, who cares.
Same what I do: I keep most of my axial film caps rated at 630VDC. I could have that one variety and buy in bulk.
MrFixer55 why do you say putting a 500wv ECap in an AA5 radio is not good? Not sure but I may have done so.
Dan
I did not read anything like this im MrFixr's post.
Any AA5 radio would have its B+ under 200V, so 500V electrolytic is just fine there.
Not just that, B+ in transformer sets is more like 300-plus Volts, and before the filter it is closer to 350-370VV and briefly shoots up to 420-450V before the load kicks in, and they used 450V caps originally (I use 500V). And even this is just fine.
I need to replace he grid cap wires coming out of the IF expander unit. Has anyone done this and if so how?
Dan
I need help figuring out what the pin numbers are on the 6H6 tube. Can some one please label the pin numbers?
Thank you,
Dan
https://www.radiomuseum.org/tubes/tube_6h6.html
Look here.
Plates are 3 and 5, Ks are 4 and 8, filament is 2 and 7.
Regarding replacing the grid cap wire, I snipped the old one off leaving a bit of a "stump" on to which I soldered the new wire. I put a bit of silicone tape around the new wire so it couldn't easily be yanked out through the hole in in the ceramic piece at the top.
You don't really want to mess with the tiny transformer wires if you can help it. That's why I leave a bit of the old lead in place to connect the new one to.
Greg O.
Whitehall, PA
Greg those are some pretty hairy looking coils in there. Yeah I agree you don't want to mess with those coil wires.
I took out the Magnetic Tuning Transformer to replace the 490K resistors. Here are some pictures of whats in there in case someone was interested.
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
Vlad; I thought your brown RCA portable looked familiar, I have one that is very similar, the RCA-Victor model BX-55....Arran — 02:31 AM
Value of capacitor
OP is "original poster"klondike98 — 11:05 PM
Value of capacitor
What is an OP?  Looks like the “OP” mistakenly typed electrolytic.  Lets forgive him.Joe Rossi — 06:31 PM
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
There are currently 569 online users. [Complete List]
» 1 Member(s) | 568 Guest(s)
