Circuitry had me fooled.
I was working on the Monitoradio that I bought earlier this month because when I first tested it I had no sound. Going by the Sams lit I found all voltages and resistance checks were normal. I could even force a strong IF and RF signal thru it. So why did I have no sound? looking at the bottom of the chassis and the picture in the Sams I noticed that there were extra parts that did not show up in the Sams, even a dual control. Turned out that this model, PR-155B2, has a squelch control installed. Receiver works just fine.
Nice sleuthing!
Noise? I don't hear any noise.
HI Jim,
I found one of these last summer, haven't taken the time to go thru it. Thanks for the post.
Jim
Spring Lake MI
Video Source for Predicta
Thank you VERY much for this description. Much appreciated!1962300 — 01:43 AM
Hello jeff, Far as C8,C11 50ufd ,25volt ECE-A1EN470UB , 667-ECE-A1EN470UB far as C8,C11 make sure you use Bi-Polar/Non...radiorich — 09:46 PM
Thanks Radiorich! I ordered and received the capacitors you so kindly laid out part numbers for. I am unsure about C-8,C...Jeffcon — 04:05 PM
Rogers Majestic R-646
Hello Vlad. In general, in my opinion, restoring a wooden case, even in such a bad condition, is much more pleasant than...RadioSvit — 01:23 PM
Paul Philco322 Yes, you are right. Bot only this very terrible and dangerous method as on picture can solve this prob...Vlad95 — 12:18 PM
That's a drag. I had a set from a heavy smokering environment and the nicotine was just sponged up by the Bakelite case,...Paul Philco322 — 12:07 PM
Here's how I did a similar restoration in detail. But it was easier anyway. (these radios are much smaller and lighter) ...Vlad95 — 12:05 PM
Hi  MrFixr55 It is nice that the tuning capacitor is covered; it should be cleaner than the rest of the chassis. No...Vlad95 — 11:54 AM
Chassis looks pretty good. I have seen that type of cosmetic condition deemed acceptable by many, we all have our standa...Paul Philco322 — 11:53 AM
Hi Vlad, Definitely keep us posted on the progress. Your experience will help newcomers to this hobby. I hear y...MrFixr55 — 07:47 AM
There are currently 1331 online users. [Complete List]
» 3 Member(s) | 1328 Guest(s)
