Threads: 1
City: Meridian
State, Province, Country: Idaho
Threads: 127
City: Omak
State, Province, Country: WA
Hello Jonnym ,
First all I wanted to welcom you to the Philco Phorum .
As this set goes has anything been done to it recently like any new parts added ?
because if not that might be your issue anyway we would need more information .
The volume control is it scratchy sounding when turned ?
Threads: 573
The bottom lead of the vol ctl in 96 is connected to the Center Negative through a 70K resistor (part of an RC filter).
So it is never really at zero vol, but do check that #33 resistor to be 70K or near. If it is much higher or open, the vol will remain high.
https://philcoradio.com/library/index.ph...chematics/
Also see if the potentiometer is open. If it is continuous, even 1M or so, it is OK to use. Clean it (it is a wide paper carbonized band with a brass roller as a wiper) without rubbing it with anything: just spray Deoxit F5 (Fader lube) and let dry; DO NOT use contact cleaners like Deoxit D5.
This is my 96 thread from beginning of this year.
https://philcoradio.com/phorum/showthread.php?tid=25548
Threads: 276
City: Wilsonville
State, Province, Country: OR
Welcome to the Phorum!
...and in addition to the annotated schematic that Mike linked to there is the factory schematic info at:
https://philcoradio.com/library/download...l.%201.pdf
Threads: 1
City: Meridian
Thanks everyone, I will pull the chassis out of the cabinet and do some checking.
The volume adjustment is not “scratchy”.
