#46
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring to. Of course any radio not a Philco you would have to provide a schematic or link to a schematic.
These tubes are local tubes and the base is kind of a shield. The center post of the tube socket should be wired to chassis ground for the shield to work. If you look at the second XXL in the schematic, you can see a dashed line just inside the tube, it is connected to ground. That's the center post. You will see components connected to the center post because it is a convenient ground terminal.
So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts of the same value. When removing a part, connect a jumper wire with gator clips to each terminal so you have a reference where the new one goes.
#47
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts of the same value. When removing a part, connect a jumper wire with gator clips to each terminal so you have a reference where the new one goes."
Thanks Rod,
I definitely only replace one part at a time, that alone has been enough of a headache with this chassis.
#48
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resistor that connects to the tube wasn't correct. I swapped them initially based on the schematic and a resistor chart. I am double checking with my pictures; there's only 14 so I'd rather be safe than sorry.
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
There are currently 915 online users. [Complete List]
» 1 Member(s) | 914 Guest(s)
