Threads: 105
City: Calgary, AB, CA
Threads: 105
Threads: 129
City: Omak
State, Province, Country: WA
Hello Dan,
Wow that cabinet looks incredible !!
I bet when it's all back together it will be a really nice set to enjoy .
Off, the subject how is the weather up there it hit 102 degrees here yesterday.
Threads: 105
Thanks for the comment. The weather up here is quite nice. not too hot . It get s up to about 75F .
Dan in Calgary
Living in Calgary Alberta
Threads: 425
City: Boston
I like how the grille work is so sturdy yet pretty. So many radios with delicate grille work get broken and are hard to restore. Good luck with it. Paul
Threads: 105
Hi Paul;
The grill pillars were quite easy to take out .They only had a rear nail in the top rear of each one.
It is a lot easier to strip them when they are out.
The stripping on this radio was not as hard as some others I have done.
I have seen photos of this model with the grill bars missing, and I wonder how that would happen,but some people don't care.
I am glad I can get this one back to it's original look.
Dan in Calgary
Threads: 46
City: Roseville, MN
Dan, I love your cabinet work. If you enjoy it, do as much as you can now. I used to have the physical ability but my back and arthritis in my hands put an end to this kind of work. So I'll just admire your accomplishment.
Threads: 105
Thanks
I also have some arthritis in my hands, and it is getting a little harder to lift these radio cabinets
on and off so I can work on them. I find it very enjoyable to make the radios look like they came out of the factory.
Sometimes I do change the toned lacquer a little, but many of the old radios were very dark and I lighten them up a bit.
I am glad that the guys on any of the forums like the cabinets.
I do get a lot of comments , so I must be doing something right.
Dan in Calgary
Threads: 46
City: Roseville, MN
I like your approach to the dark finish. IMO to much dark finish hides some of the features of the cabinet. I used dark finish to highlight certain aspects.
Threads: 54
I have noticed that Marconi cabinets, from that era, didn't really go overboard with the shading lacquer, at least on the higher end cabinets. Unfortunately my only pre war Marconi is a model 157, and both ends of the cabinet were very heavily shaded, along with the grill, even the walnut veneer was over sprayed with tinted lacquer, though a more light colour.
Threads: 105
Threads: 129
City: Omak
Hello Dan,
That really turned out very nice and I also like that color it is not to dark .
I Have General Electric model L-916 for 41 that I want to refinish the two big issues is part of it has photo finish and someone might have used some poly on part of it.
Threads: 105
Help with Supreme 599
This tube tester wont work to test tubes or center the needle but works on DC volts. I checked the line adjust rhehostat...daveone23 — 07:04 AM |
[split] New member...
Far as I know, that plastic insulator should be mica. I don't know if plastic is an equivalent insulator.RodB — 10:51 PM |
Ok, I think I'm about done. I've got one anomaly left but other than that, it is working great and picking up lots of s...HowardWoodard — 09:34 PM |
Abandoned Zenith 9-S-367 located/Galesburg IL
As I looked through Zillow I noticed an abandoned house for sale in Galesburg Illinois for $14,900.
There appears to be...bridkarl — 05:42 PM |
Yesterday checked Mouser for the price on some caps and was curious about the mica equivalent. The 27pf 1kv ceramic is 2...RodB — 09:58 AM |
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM |
Vlad;
I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM |
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM |
Bob, this is the wrong sequence to look for problems and setup circuits.
Always start checking the signal path from the...Vlad95 — 12:19 PM |
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM |
There are currently 438 online users. [Complete List] » 1 Member(s) | 437 Guest(s)
