Threads: 1
City: Southampton
State, Province, Country: New Jersey
Threads: 54
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusual for Philco to mate whatever chassis they had on hand to it. The speaker looks like an RCA one, and the transformer sitting behind it was just butchery, I think that those sets may have had the transformer mounted under the chassis.
Threads: 1
City: Southampton
I realize there is a lot of butchery going on here to get it playing. I plugged it in and it didn't play! LOL But all tubes lit up and the audio section is working. (Scratchy volume control.) I need to pull the chassis to see how they wired this outboard transformer. Only 7 wires going to it and 10 are required. Curious how this thing is getting 5V and 2.5V. The 2 resistors, measuring ~ 1500 ohms total, are soldered to the outside of the remaining filter cap that is insulated from the chassis. The other end going to the B+ center tap of the transformer. Must be lowering the B+.
Thanks for the clue on the speaker.
Threads: 574
Not sure I understood. There is that power transformer, it makes 5V for the 80 and 2.5V (marked as "A") for the rest of the tubes.
Unless I misunderstood what's being asked?
Oh...and in 50- series the power transformer is under the chassis.
Threads: 425
City: Boston
I would love to see the underside of that set, good luck and when you get that all cleaned up and running you will have a unique set. Paul
Threads: 1
City: Southampton
Morzh
There are only 7 wires coming off the transformer. 3 for B+, 2 for 115 in and 2 for 5V to the 80. Maybe there is another transformer under the chassis providing 2.5 volts to the other 4 tubes. I've used run/start capacitors to replace ballast resistors but don't think it would be practical in this case.
My main question is if this set was assembled as a model 51C, possibly near the end of the 51 chassis run? Only the model 52C shows in my searches so far, including radiomuseum.org and Philco Radio 1928-1942, originally by Ron Ramirez. I guess I'll have to clear my bench to pull the mess out to investigate further. Pictures forthcoming!
Arran suggests Philco used up a 51 chassis to complete this set.
I have an AK 20C that is mounted in an AK cabinet that was modified for the 20C panel to fit. The cabinet never had a chassis/panel in it previously and there are no signs of a tag or label on the underside of the lid. This implies an employee cobbled together components to make a radio for his use.
Threads: 574
I suggest you take that look under the hood eventually.
Makes little sense to try to figure things out without looking at everything.
Threads: 54
The model 51 and 52 are identical mechanically, I'm not sure what may have been changed between the two chassis but one will very easily bolt into the cabinet of the other without drilling any extra holes. Philco did something similar with the model 21, it used the same chassis as a model 20, but the same cabinet as the later model 70, but the control layout was slightly different, as Mike (Morzh) can tell you the model 20s are a TRF, not as good a model 70, but not terrible either. Philco had it's own cabinet shop so it wasn't unusual for them to do things like use up left over chassis, in new cabinets, before starting a new production run, in this case they didn't have to do anything special. It may have been a factory job, or someone had an empty cabinet that they wanted to use later on, but it's conjecture on my part, either way. I can't swear that it is an RCA speaker, but that welded rear bracket was a sort of trademark with their speakers, and the basket looks like something from an RCA (or CGE) set from the 1937-38 period.
Vlad;
Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM |
Rod;
I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM |
Rogers Majestic R-646
Vlad;
It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM |
Hi OSanders.
another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM |
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM |
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM |
Arron,
Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM |
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM |
Thx Vlad.klondike98 — 06:54 PM |
Hi Arran.
I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM |
There are currently 269 online users. [Complete List] » 1 Member(s) | 268 Guest(s)
