Unidentified Philco Bakelite
This unit just became available on a local Canadian marketplace. The seller is unable to find a model number on the back panel. Just wondering if anybody recognizes it.
The knobs I would guess are not original. Paul
Looks like a Tropic of some sort.
Possibly a UK radio. I make this presumption based on the Long Wave band. A photo of the back available? Take care, - Gary
It's a British Philco, likely from the early 1950s. It has a very common layout for British sets starting in the post war era, a vertical slide rule dial, with short, medium, and long wave bands, all measured in meters rather then by frequency.
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
Rogers Majestic R-646
Vlad; It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
There are currently 270 online users. [Complete List]
» 1 Member(s) | 269 Guest(s)
