Vlad;
You may have noticed that Motorola greatly simplified the chassis, and cabinet layout on the model you bought. They went with a more conventional layout with all of the batteries stored below the chassis, and all of the electronics in the chassis, rather then congregated all around the main chassis. One drawback might be the silver mica caps in the IF cans, by then Motorola was using the 3/4'' square Automatic style IF transformers I think rather then the round ones. One thing I will say about every Motorola radio I have had, they usually performed well once restored, and they though of things like disconnecting antennas, and speakers, for servicing.
Thx Vlad.
#48
Arron,
Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar. They are also very similar externally.
If you want to work, lie down and sleep, and everything will pass.
#49
Vlad;
Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp out the steel cabinets, all they had to do was put a new front panel, and door on to disguise it. I guess you could say that the chassis was a refinement of the 1948 model, electrically they would be very similar, pretty much all "three way" portables from that era are, some would have a tuned RF stage, others not. I think that the largest change was that many started using a 3V4 audio output tube, which gave better performance then the 3S5. There is a green version of your set out there as well, I will have to see if I can find one.
Philco 37-116 Cabinet Repair
It looks to me like the structure under the veneer may have expanded from humidity cracking the veneer on the surface. W...Arran — 09:42 PM
Help with Supreme 599
Iam only getting 4vac out of the tranny For the 80 filament. The line rheostat Looks fine and the tranny is getting 11...daveone23 — 08:45 PM
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
There are currently 724 online users. [Complete List]
» 1 Member(s) | 723 Guest(s)
