Electrocution Risk?
I'm starting to work on my Philco 40-180 I got recently, but before I started messing around with the insides, what are the risks? If it's unplugged, am I in the clear? Will anything discharge when I touch it? I know some old tube TVs can still hold a charge even if it's unplugged. Just checking.
Dark
If the old electolytics can still hold a charge it'll zap you. Discharf=ge them through a good 10 K resistor for a minute just to be sure. Arm to arm discharge can be a real problem, especially as we age. Please do not ask me how I know.
I agree. If the set is unplugged, the electrolytics can still hold enough of a charge to shock you. when the set is plugged in, I always use the "one hand in pocket" rule I was taught in electronics servicing at tech college, which means to work on an energized circuit with one hand only, that way if you touch the circuit the shock will only travel through your hand, which will hurt but won't do serious damage. the real danger is if you make a path for electricity that will allow it to pass through your body, which can kill!
Ok good. Shocks I can handle, the shocked to death is what I'd like to avoid.
Thanks
Starting to get off-topic, but...
An electronics professor I had in college talked about working on a Navy submarine. He said when it was really time critical to find blown circuits he would stand on a rubber mat and touch each circuit with the back of a finger. He said he wouldn't get much of a jolt as he was insulated, but he could "feel" the current flowing by his hand. If his arm or hand contracted from the electricity it would tend to pull his hand off the circuit instead of grabbing it harder.
I think he was nuts!!
It may or may not hold a charge, many AC sets have a discharge resistor between the + and - of the filter cap of severaly 100,000 ohms.
I've been shocked a couple times both from stupidity. Icon_rolleyes
First time was from touching a lead on an IF transformer on an Packard Bell AC/DC set. 250VDC into my finger which also touched the chassis at the same time hurts like a BI**H.
Second was from touching the electrolic caps in the power supply of my A.C. Dayton when I didnt have the radio chassis connected (was testing the newly rebuilt power supply). Cap was a 10uf 450V.
To me the high DC voltage was the worst, but getting shocked is never a good thing and can always be avoided. I now use the one hand in pocket when poking around in a live radio.
-Keith
Spend the few pennies on bleeder resistors when overhauling a set to make the chassis a little safer after shut off an disconnect. Plenty of information here and elsewhere.
And get yourself a wooden stick about 18 inches long. Make one end look like a pencil. Use this as a probe. It will show you problems while power is on the chassis.
Chris
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
There are currently 1115 online users. [Complete List]
» 1 Member(s) | 1114 Guest(s)
