RCA 16 tube 18K console recapped
Threads: 108
City: Calgary, AB, CA
35F with radio...in an enclosed space? Radio in the open makes little difference in temperature
Threads: 55
City: Roseville, MN
Which tube is in charge of doing windows?
Threads: 437
City: Boston
It's going to be over 100F in Boston today. Paul. I know weather thread
Threads: 108
Sorry guys MY post should have read 35F with RAIN.
Dan in Calgary
Living in Calgary Alberta
Threads: 23
City: Greenlawn
State, Province, Country: NY
Hi Dan,
Looks like a neat radio. Can't find the schematic. If you can post a link that would be great. Is it an 18K or is there a digit missing?
Looks like the set has 6L6s for the output stage, and the back on the speaker area indicates that RCA Victor had some idea of baffling and / or tuned ports. Love the "Magic Brain" Sticker. They used that for quite a while in the 30s. Apparently, it was in a smoker's house.
As to the tube count, RCA actually ran an ad on one of these higher end radios similar to this one, explaining that each tube had a task and there were no tubes in there merely for "tube count" For example, there appears to be an advantage in fidelity with the separate 6H6 detector and audio amp instead of a 6Q7 Detector / 1st AF Amp.
How far up north or high in the mountains is Calgary? I know it gets cold in the winter, but 34 Deg F in June? Do you mean 34 Deg C? Was abut 99 Deg F / 37 Deg C here in Long Island, NY, Southeast tip of NY, the past few days.
Threads: 108
My post was right 34 degrees F. It was cold.but yesterday it was 70F.
Sorry I don't have an attachment
Dan in Calgary
(This post was last modified: 06-26-2025, 09:38 AM by Dan Walker.)
Threads: 23
City: Greenlawn
Dan, 34 Deg F in the summer is kind of amazing. But I just went to Wikipedia and I guess at about 3500 ft above sea level and about 51 Deg N latitude vs my location of 200 ft above sea level and 41 Deg N latitude, that may explain it.
Pix seem to show an add-on radio - phono jack on the back. did this go to the terminals at the lower left or was it hard wired to the chassis originally? Wonder what it sounds like with a hi fi signal from an MP3, CD, etc injected directly into the audio section.
Good luck with the radio.
Threads: 108
There is no phono jack ,on the back but there are instructions as to how to hook up a Record player to the radios amp.
I made an adapt or so I can use my MP3 with this radio BUT I have not tried it yet.
As the radio plays good ,there is lots of sound. It is a BIG 16 tube RCA, so It should sound good
Dan in Calgary
Threads: 12
City: Seattle, WA
MrFixr55 - The model number is RCA 816K.
Threads: 108
Threads: 7
City: SPRUCE GROVE
State, Province, Country: Alberta
Cabinet before and now  - absolutely great work.
Congrat !
If you want to work, lie down and sleep, and everything will pass.
Threads: 23
City: Greenlawn
  Really nice job! What a beastie! Not a Scott Philharmonic or a Zenith Stratosphere, but one of RCA's best. 25Watt output! If only this had a better speaker than a single 12". I it heresy to sneak a tweeter mounted coaxially to the speaker?
For anyone interested, here's the schematic from Nostalgia Air:
Great final result. Nice addition to every room.
Threads: 46
City: Lapeer, MI
State, Province, Country: USA
Gorgeous radio! Congratulations. Joe
| hello david,
| Hello Everyone,
There are currently 2132 online users. [Complete List] » 1 Member(s) | 2131 Guest(s)
