1930's Philco Steel Tube Shields-Were they plated?
Hi all, Have numerous Philco tube shields for radios I'm working on from the 30's. Seems like I read some info some time ago that they were plated with zinc or a zinc alloy. Can anyone confirm this and has anyone "restored" these shields so they look close to what they were like when new? Thanks, Ken Kidd
Most likely just galvanized if that. Just make sure that the base still conducts with the sleeve if you paint 'em.
Actually, yes, they were plated...with tin.
You can get by with painting them, if you use Krylon Satin Nickel. The Satin Nickel is conductive!
Thanks for the info-will try the Krylon and see how one turns out. Ken
Well, never enough yet how much is too much? I ordered some spare parts from a couple vendors in China and now have ship...TV MAN — 10:49 AM
This Marconi was a bit of a challenge. It was totally missing one electrolytic  capacitor, and the photos show a couple ...Dan Walker — 10:48 AM
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 1143 online users. [Complete List]
» 1 Member(s) | 1142 Guest(s)
