Need info on these caps
I am trying to recap a philco 38-4 and need some info on the tall elctrolitics on top of the chasis.The philco numbers on the cans are as follows.30-2200a,30-2201a and 30-2212a.What parts do i need to order.???Any info you could provide would be greatly appreciated by this neewbie.Thank you in advance.
Hi Kelly and Welcome!
What you are looking for to replace the two filter caps are: for #64 it's a dual job original value is 10 uf and a 8uf. Would replace with two 10uf @ 450v. #66 is an 18uf original replace with a 22uf 450V. There is also #26 a 16 uf replace with a 22uf @450v
A lot of these caps aren't standard sizes anymore so the values I've given you are standard size now. Service info can be found here:http://www.nostalgiaair.org/Resources/250/M0013250.htm From the service info it looks like it ought to be a good playing set after servicing.
Good luck w/it
Admin Note: Made URL into a link.
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
There are currently 580 online users. [Complete List]
» 3 Member(s) | 577 Guest(s)
