I don't think I will be restuffing this Black Beauty.
It is not authentic to the radio. BB is late 1940-s and this radio is early 1930-s.
It was a repair.
I took the resistor board out. Too involved and teathered, with too many stubs to unsolder to handle it while still not fully free.
I still use parallel resistors to remedy those that do not exhibit signs of deterioration and simply drifted up a bit more than acceptable.
This one is 2M.
It drifted to 2.7M.
I needed to put 8.5M in paerallel. I had a bunch of 4.7M resistors from a kit from mAmazon (their tolerance more like 10% vs promised 5%), one being 5.7M....I put two of the lowest values, 4.65M in series, in parallel to the original one and got some 2.1M.
Then I will need to clean the board. Grimy as a tar pit.
Threads: 226
City: Omak
State, Province, Country: WA
hello morzh,
looks good nice job on the resistor .
I skipped the day yesterday.
Wanted to go down the basement, walk on the treadmill and then do some work, but then saw the news about Peter.
So I had to pour me 1-1/2 oz of Vodka, sit down, drink to his memory.
After that, of course, no tredmill fast walk or working on radio was possible.
So, today, other than taking out that board, I restuffed a few caps.
I hope, my photos and my memory will not fail me when I start reconnecting all this.
Threads: 46
City: Lapeer, MI
State, Province, Country: USA
Mike, Great work. I would've never thought of paralleling resistors, a nice touch. Nomally I'd rip them out and replace 'em. Be strong. Joe
Joe
often times I do the same, but there are places where a resistor to be within tolerance is more important thn in others (like, to me AVC being 2M or 2.7M would not even make me touch it; this one is in series with the Control grid, so the drop caused by even a small current can affect it) and so some resistors I correct and some I do not.
Those that I do correct, I either replace or parallel.
Those I parallel are the ones that went outside of tolerance but within reason considering the age.
2.7M vs 2M is within reason to me, over 90 years.
Within reason means speed of change. This one went up 30% over 90 years., or 0.33% a year on average.
Then let's say it went to 4M/5M. To me this is bad, same as if it were open. I will yank it and change it.
Another possibility if a large resistor went up so much, that you could parallel the intended value resistor to it (say, 10K went to open or 100K and you parallel a 10K there) and hide it behind the original resistor. Sometimes I do that too.
Mike;
It seems to be a matter of production quality of the resistors used, in that Westinghouse 801 that I repaired all of the resistors, except one, were within tolerance, if not spot on, and they were all BED code "dogbones" I've heard that the late 20s RCA AC sets are the same, but will verify.
Threads: 55
City: Roseville, MN
Arran,
We also have to consider the environment they endured. For these higher values not much current is involved but it may have been physically close to a high temperature component or humid conditions which, over time, will affect the value. And that's when the quality you bring up comes to focus.
Rod
I've seen 2M being open or 10M.
Some of the 100K or 250K or so in Philco 20, I remember were fully open, but those were at least conducting something. Those that come from the wire-wound, one feeds the detector plate and the other Screen Grid. Forgot which one.
Speaking of out of tolerance resistors, this type I change.
A 1M that is exhibiting 2M.
Now, there are three resistors, R7 / 3.5K, R6 / 6,5K and R5 / 8.5K.
Obviously they are power-dissipating type, as all were discolored.
All went down in resistance (I've observed that with Philco power dividers in Philco 60 and similar Philcos, for the power divider resistors, a lot).
The 3.5K was 2.5K and the only one that retained some colors and did not break when simply touched.
The 6.5K was broken (I broke it but without any effort, probably just touched during the board handling), and the 8.5K was 5K before it also broke when slightly touched.
I was able to use paralleling/serializing and got pretty close to the requir ed nominals, plus I think I have good margin on the power ratings.
The rest of the resistors were either right on the money, or pretty close, so I left them.
This is how it looks now.
Mike;
I guess I forgot to post my previous comment about replacing the "Black Beauty" cap. I was thinking that if you had some thick paper you could make a replica of one of those tar filled caps.
The Rogers 10-60 I have was similar to this RCA 140, it also has two resistor boards, but they mount them parallel to the rear apron, and the left side with standoffs, and connected them to the tube sockets, and other components, with rubber/gutta percha wire. Someone had already replaced some of the power resistors mounted on them, crudely, so I removed them, and after confirming whether the values were correct, or not, reinstalled them. They used wire wound resistors with a black enamel or cement coating, which look like "Dogbone" style carbon resistors anyhow, so i replaced the rest using similar resistors, brown or black. In that set the ends of the resistors and caps can be seen after you remove the bottom cover, so I decided to restuff the original caps, and old replacement caps, and restuffed some suitable looking paper caps from my junk collection. I wasn't concerned about whether the parts were factory originals so much as hating the look of daffodil yellow replacements in a pre war radio, if I could make it look like maybe some of the parts were replaced during it's service life that was fine with me.
Threads: 226
City: Omak
Hello morzh,
Yes, when I was at work friday I thought of Peter alot !.
I hear you on remembering how to wire this I have my Philco 38-10t that is still not finished.
Threads: 46
City: Lapeer, MI
Mike, I've never seen a dogbone break like that. Fossilized is what it looks like. I don't think the replacements will look like that 90 years down the road! Joe
Threads: 69
City: Kansas city, MO.
Here is one I pulled out of an rca victor model R-14.
It burned in half. It was under one of those resistor boards and the board was riveted to the chassis. Real pain to replace.
https://imgur.com/a/du7wJnp
Threads: 25
City: Lebanon
Carbon comp resistors will typically increase in value over time and environment even without being powered. I have an assortment of Allen Bradley carbon comp 1/2W resistors in original packaging from the 1960's and almost everyone increased in value by 10-20%; the higher value ones more increased in value than the lower values.
Steve D
| And life just keeps getting more complicated. By dconant.
Dittos'Jimradio — 08:01 AM |
| hello david,
| Hello Everyone,
There are currently 1962 online users. [Complete List] » 1 Member(s) | 1961 Guest(s)
