Should I or should I not
Hi All
Here is the cabinet for my 39-116, the question is: should I do anything with the finish or leave it alone. It is not perfect, but can I with limited (and I mean limited) ability to refinish it, Icon_sad I am thinking I will leave it as is. the front and sides look pretty good but top is not too good. Also the speaker grill cloth is faded but is o k. So all comments are welcome. Joe
[Image: http://i927.photobucket.com/albums/ad118...03482r.jpg]
[Image: http://i927.photobucket.com/albums/ad118...03481r.jpg]
[Image: http://i927.photobucket.com/albums/ad118...03479r.jpg]
[Image: http://i927.photobucket.com/albums/ad118...03478r.jpg]
Looks good as is. I would just give it a rub down with a little bit of Howard Restor-a-finish.
I think It looks great the way it is. I always thought an item was worth more in it's original state, yet I go on the bay and radio's that are given freakish Steinway finishes are fetching good money....go figure....
Hi Joe,
The finish on your set looks to be in pretty good shape. I wouldn't try to refinish it. Like Motorola man mentioned, I would try Howard Restore A Finish on it. I've used it on a couple of sets in my collection where the finish was old but okay, and I was very happy with the results Icon_thumbup! It's also very easy to use. I found it at my local home improvement store and I believe that Home Depot carries it as well. Good luck with it!
I'll ditto the comments above; it looks nice in the photos. Try some Howard Restore-A-Finish in Walnut, and see how it looks then.
I agree with the gang, Howards is pretty good stuff, I just made a crummy looking cabinet very respectable with a good cleaning, one application of Howards, and the some Orange Bee's wax. Polish well with a soft cloth, voila! Icon_biggrin
Fine looking set. Bringing back the original finish is always preferable to restoration unless the cabinet is just too far gone.
Looks great!
Follow Ron's suggestions. You never find them that good, generally, depending on previous owner(s).
Chuck
Another finish restoring method which I use on all of those thick gloss finishes is a rub down with liquid medium to coarse automotive paint compound followed by a paste wax. This method cleans the junk off, and restores a spectacular original gloss finish.
Although it sounds outrageous, after the compounding I wipe over any scratches and crevices (or the entire radio) with a dilute solution of walnut wood stain. It doesn't stain the wood or lacquer but permanently eliminates the minute and major scratches and wear. Just wipe it off with a rag before waxing.
Pete AI2V
Adding my two cents' worth to the above, I concur. Go with the minimalist approach. It looks pretty doggone good from where I sit.
Hi all
oK I am going to clean it and leave it as is. Thanks to all who commented. Your input is valuable. Joe
Philco 60 Squealing
Usually a wave trap is for keeping IF signals from entering the antenna and from leaving the antenna. You feed an IF sig...RodB — 09:30 PM
Philco 60 Squealing
I just peaked it for the best signal at 600. NULL it for IF frequency, originally it would have been null for 500kh...Chas — 08:05 PM
Philco 60 Squealing
Wavetrap no longer matters.morzh — 05:19 PM
Philco 60 Squealing
Rod, I had checked out your suggestions but did not help. I did solder the ground rivets to the chassis as Chas suggeste...dconant — 04:52 PM
37-690 Bass Choke Replacement
Yeah, I know, Mouser and Digikey don't have "big iron" components. For some reason Philco was messing with the...Radiodial — 04:25 PM
Yes, I just had to deal with that while repairing the 37-604 Philco. Exactly that value choke was gone. And the current ...morzh — 03:52 PM
Ah, now where to find one. I've into this before on smaller sets, I now recall. Hammond makes one that is only rated...Radiodial — 03:27 PM
Philco 38-7 Speaker
Ask the admins to put them together. As for the renaming, while inside the thread, you simply press "New reply&quo...morzh — 02:23 PM
This is the parts catalog. 32-7528 choke is 65H, 10mA, 2,250 Ohm inductance. Find a suitable one.morzh — 02:18 PM
While troubleshooting the no bass amplification issue, I think I found the culprit. The choke #104 is reading 164K ohms....Radiodial — 01:42 PM
