Philco 610B Tone Control 30-4318 caps
Hi all, Have some conflicting info on the cap values for this tone control. Both my Philco schematics(one early and one later production) list .01 and .02. I have Ray's original "Philco Condensers and More" ( Great resource book!!!) which lists a .02 and a .003 for this tone control. The Philco Repair Bench does not list this tone control. Does anyone know which would be the correct ones? I'm assuming the .02 value is correct. Thanks-Ken
Those caps aren't that critical, either combination will work. Use what you have, just follow correct layout (placement). Yes, the Philco Condensers and More book is nice to have!! Best of luck with your restoration.
Thanks for the input. Will probably go with whats listed in the Philco schematic-Ken
Go with to .003 and .02. That will give you a fair amount of difference between the two setting.
Yes, agree with Terry, .003 and .02 are a good combination for steps in tone.
Philco 37-116 Cabinet Repair
It looks to me like the structure under the veneer may have expanded from humidity cracking the veneer on the surface. W...Arran — 09:42 PM
Help with Supreme 599
Iam only getting 4vac out of the tranny For the 80 filament. The line rheostat Looks fine and the tranny is getting 11...daveone23 — 08:45 PM
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
There are currently 728 online users. [Complete List]
» 1 Member(s) | 727 Guest(s)
