Adding a second record changer to a 46-1213 Console
I would like to add a second record player to the 46-1213 console to provide 33 1/3 RPM capability. I was thinking of the AT-LP60 which has an AT dual magnet cartridge, with a switchable preamp providing about 36 DB gain.
The current changer cartridge output feeds into the transformer, out of the transformer through an R/C network of 220K resistor and a .001 MF condenser parallel with a 4.7 meg resistor to ground into the grid of the 7AF7 phono amplifier/phase inverter.
Question: What do I need to do?
I would wire it up without the preamp as the original was set up the a mag cartridge. Both are low impedance so I think it should work out fine. If you can't get much audio level out of it then I'd add in the preamp.
Thanks Terry, I do appreciate it. I want to keep the console absolutely original, the cabinet looks as if came out of the factory today. Photos to follow. Icon_redface
Would I need an A/B switch or both connected in parallel? The 33 would get very little use, my calculus would be to place it upon a shelf above the console, not on the console itself.
You should put a switch between the two.
Philco Battery-WWII vintage
Would an output transformer if weak, cause the problems I am seeing with lower B+ voltage? murfmurf — 01:22 PM
Hello murf! I merged the threads. Please do not start new threads regarding the same radio. Take care, - GaryGarySP — 10:21 PM
Regarding picture 5 on page 1 of this thread this capacitor is #40 on scematics diagram - 4mF+4mF. Black wire is "-...Vlad95 — 09:01 PM
That's a dual 4 MFD, red and green are both 4mfd and black is common negative. You should be able to see them in the pow...RodB — 08:58 PM
Can anyone help me figure out a capacitor that has 3 wires coming out of it red and green on one side and a black wire o...osanders0311 — 08:14 PM
Two small radios from France. Restoration and review.
Greetings; I think that it's possible that the assortment of components was the result of post war parts shortages, a...Arran — 12:18 PM
Unfortunately I can't inject any audio into the volume control. It is in the primary circuit of the antenna coil, not in...Stormlord5500 — 09:32 AM
There are currently 664 online users. [Complete List]
» 1 Member(s) | 663 Guest(s)
