tube very hot philco 42-1013
I recently got a 1942 philco console radio phonograph and it works but one of the tubes gets boiling hot and I'm afraid to use it any more. The capacitors inside look poor but they aren't leaking . Would it be a good idea to replace some of the capacitors feeding this socket or others also .---I just realized that the rectifier tube wasnt even in the unit but it still worked is this possible ?
It could be that the rectifier was replaced with modern diodes underneath the chassis. Unless other measures are taken sometimes that leads to higher voltages and may be related to overheating. But if you're referring to the audio output tube it runs quite hot in normal operation.
BTW, "leaky" caps refer to internal leakage not necessarily visible from the outside. If they are the original paper caps they probably are leaky and should be replaced if you're going to use the radio often.
Thanks for that info. Yes there are two very large what I thought were caps under the socket that don't look original. I'll start replacing some of the old caps to be safe . I can replace a 400v .001mf cap with a 630v .001 is that correct? Thanks for your help im very new to this.
yes the 630v caps will be fine in almost every application. It's about all I use anymore less parts to keep around and modern caps are smaller than the 70 year old ones.
John
Las Vegas, NV USA
Philco model 40-100
Arran, I restored 2 Canadian battery-crank telephones for a friend a while ago, a Northern Electric (Canadian version of...MrFixr55 — 08:04 AM
Road Trip for a Philco 46-480
Beautiful work, a 79 year old radio brought back to life. The first FM radios for me, a little iffy, had some I just cou...Jimradio — 08:01 AM
I was a field engineer for a biomedical company for many years. Many was the time that I was driving home from NYC in t...MrFixr55 — 06:40 AM
Don't laugh folks, I have not been above taking a chassis into the bathtub (when Ms. Fixr was out of the house), taping ...MrFixr55 — 06:02 AM
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
There are currently 565 online users. [Complete List]
» 3 Member(s) | 562 Guest(s)
