Philco Power Transformers
Is there a way to get the transformer specs from the Philco part number?
Thanks
Yes there is. Let me know the PHILCO part number on the shell, which will start with a 32-xxxx or jusr four digits.
I have Philco Parts Catalogues from the about the mid-30s to 1945.
There are some already on my website in the Parts Values section.
Regards,
Chuck
I need one for a 38-1. The print lists part as 32-7889
I found one in a junk chasis part 32-7597N. I would like to find specs to see if it will work.
Thanks for you help.
Jim
Jim,.
No, unfortunately, it won't work. The correct p/n is actually 32-7869, not 7889, for the Model 38-1.
The HV secondary of the 32-7597 only rated at 100 ma. The 32-7869 HV secondary is 160 ma.
Also the correct transformer filament current is 6 amps, and the fil amps on the 7597 is only 3 amps.
Here are the full electrical specs for the correct 32-7869 used in the 38-1 (ALSO 38-2).
Primary = 110-120 vac
Secondary = 660 vac @ 163 ma.
Fil = 6.7 vac @ 6 A.
Rect = 5 vac @ 3 A. (Rect tube socket mounted on top shell)
Chuck
Thanks for you time and the correct part number.
My eyes are not as good as they were.
Thanks
Jim
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
:lol: We need to start a singing radio group! I play the guitar, so maybe get a few vocals? Anyways, Mike, I did try mou...TV MAN — 05:56 PM
And so does a barber shop quartet. mmmmmmRodB — 03:54 PM
Shadow Meter Bulb
I did try an LED bulb in place of the original but wasn't impressed with the amount of light on the dial. Seems like it ...RodB — 03:51 PM
Tim Would mounting he transformer vertically change the hum, if used without additional parts? Also, in these amps...morzh — 02:25 PM
Shadow Meter Bulb
Gary I doubt it would introduce any noise. We use similar lamps for the panel indication, 12V AC lamps: they are LEDs...morzh — 02:15 PM
Shadow Meter Bulb
Not sure if anyone has tried this but there are 6.3 volt miniature lamps in bayonet and screw-in base options available ...GarySP — 11:31 AM
Shadow Meter Bulb
Any 6.3 volt pilot light will work. I would use the brightest one I could find in my workroom. Be sure the dial is clean...RodB — 10:45 AM
There are currently 5423 online users. [Complete List]
» 1 Member(s) | 5422 Guest(s)
