Philco 39-7 resto
#31
Good idea. I will do so later today.
Hope the shows were good. On the weekend, we have old radio shows on at night on one of the AM stations. Looking forward to listening to them once the radio is working. Icon_smile
#32
Very good. Don't know where on the planet you are but there's a couple of AM stations out of Canada that play OTR in the night. One is at 740kc runs 10-11:00pm Monday-Thursday and 900kc around 10:00- 3:00am or so M-F.
Enjoy!
Is this your set? I have the feeling we are talking about more than one here.
http://www.nostalgiaair.org/PagesByModel...013301.pdf
#34
Just one set. But pwr trans was replaced and it uses an 80 instead of the 84 tube.
Thanks, missed that.
#36
Yes, just one set. The power transformer was replaced with an Inca C60 ... no idea what that means. I haven't found any info on it.
Also, the 84 rectifier tube has been replaced with an 80 tube. Some wiring does not match the schematic, but not very much. I think this has been done due to the transformer replacement, but not sure. There is no evidence that there was a problem, insofar as I haven't seen any noticeable burn marks, or melted anything under the chassis.
I wasn't able to test the transformer today, so I will do that in the morning before work. I do have a question. I did not mount a terminal strip for the electrolytic capacitors. They are just kind of hanging out. Could that be a problem?
#37
Regarding the electrolytics: So long as they are physically supported on both ends and the leads insulated to prevent shorts, it's OK. The old can electrolytic must be disconnected from the circuit. Depending on the physical layout a terminal strip is not always needed. Just consider what might occur if you shipped the radio and let that be your guide.
#38
Ok. The electrolytics should be ok. I have disconnected the old ones, so will check for other possible issues (like the transformer). Icon_smile
#39
I put this on the shelf for awhile, as I think there is more wrong with it than I first thought. I finished my Zenith 10s690, and thought I would tinker with this again some more.
I finished the recap and put in new resistors. I also corrected some wiring differences so that it now matches the schematic, with the rectifier being the only discrepancy. I plugged it back in, and am happy to report that I didn't burn anything up. Icon_biggrin
But, there was no change insofar as there is no sound at all coming from the unit.
Earlier in the thread, it was recommended that I do some readings with my meter. I did do those, but don't remember what they were. I will do that again, and report back.
Nicole
#40
Sounds good will be around.
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
There are currently 715 online users. [Complete List]
» 1 Member(s) | 714 Guest(s)
