Recapping 180
I've recapped my 40-180 except for about four that are wedged underneath all the mechanics for the push button tuning. The guy's who been helping with the electronics said he wouldn't mess with them; all the rest are replaced. What do you all think? Should I go ahead and attempt to remove the push-button section to get at them?
Ryan
The caps, 20, 22, 23, 24 are all mica caps and probably are ok. Although, micas have been know to go bad now and then.
If there is any problem aligning or tacking or setting pushbuttons, then they should be replace with newer silver-micas types.
Resistor 25 (33K in the pushbutton gang area) should also be checked for out of 20% tolerance and repalced if it's out of spec, just like all the other resistors in the set for proper performance and restoration longevity.
No, these are wax (3 x .05 and 1 x .01). I can hardly squeeze my fingers down there to move them just a bit.
Ryan
Then, unfortunately, they have to go, if I were you. You'll regret it in the long run as you run the set over time. If one of those caps is the AVC filter (#32 maybe?), it will eventually cause AVC (read RF/IF gain) problems and reception can overload due to excessive leakage to ground or open up and cause distortion due to unfiltered audio signal modulating the front-end gain at audio frequencies or motor-boating. If they are B+ or screen bypass caps, the set can start squealing.
See if the replacement caps can be shifted to the same point electrically, but in a new/better physical location.
Okay, thanks Chuck. That was my gut feeling but I thought I'd get a second, more qualified, opinion. Should be an adventure.
Ryan
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 762 online users. [Complete List]
» 1 Member(s) | 761 Guest(s)
