My Philco 40-190 only gets one station.
I have a 40-190 that with one button pushed (the first) receives one station loud and clear all along the dial, the tuner has no effect. With the last button pushed the same station comes in at each end of the dial with nothing in between. The other buttons or no buttons pushed get nothing but static all through the dial. I sure could use some help. Thanks.
If you're still there, Baspas...
The last button (first button from the right) needs to be pushed in on the 40-190 in order to be able to tune in stations. If you push in any of the other buttons, you won't be able to tune in anything.
Philco 45L Initial Check Up
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
There are currently 967 online users. [Complete List]
» 3 Member(s) | 964 Guest(s)
