610 volume fluctuation
Hi - I'm enjoying my recapped Philco 610, which works pretty well even though the antenna arrangement is less than ideal - but I noticed that the volume level is normally pretty low (you need to turn the volume knob a long way although it is progressive in its increase) . The other day, the volume suddenly increased massively, requiring me to dash across the room, scattering barking dogs and crying children in my wake, to turn it down again. It later dropped right back again. The effect is sudden not gradual.
Poking around, I noticed I can sometimes create the same effect by tapping the top of the 75 tube (second detector). This tube tests rather weak - I would usually have said it would be alright. Does anyone have any experience of this phenomenon, or ideas for what I should check for ?
Its not a big deal really - but has me puzzled.
Is the grid cap on the tube loose? I am talking about the silver cap that should be premanently affixed to the top of the tube, not the wire connector end. If yes, that could be the issue.
Try replacing the 75 with a strong tube and go from there. The 75 is the first audio/2d detector tube, and the volume control feeds the grid of the 75 through a .01mFd cap.
(03-16-2012, 12:17 AM)TA Forbes Wrote:  Is the grid cap on the tube loose? I am talking about the silver cap that should be premanently affixed to the top of the tube, not the wire connector end. If yes, that could be the issue.
It could also be a flakey solder joint on the lead near the clip, or the wire breaking internally near the clip, those are pretty common problems around a grid cap along with the cap itself.
Thanks for the ideas - I'll check all these points - I just want it to work as good as it can !
Help with Supreme 599
This tube tester wont work to test tubes or center the needle but works on DC volts. I checked the line adjust rhehostat...daveone23 — 07:04 AM
[split] New member...
Far as I know, that plastic insulator should be mica. I don't know if plastic is an equivalent insulator.RodB — 10:51 PM
Ok, I think I'm about done.  I've got one anomaly left but other than that, it is working great and picking up lots of s...HowardWoodard — 09:34 PM
Abandoned Zenith 9-S-367 located/Galesburg IL
As I looked through Zillow I noticed an abandoned house for sale in Galesburg Illinois for $14,900. There appears to be...bridkarl — 05:42 PM
Yesterday checked Mouser for the price on some caps and was curious about the mica equivalent. The 27pf 1kv ceramic is 2...RodB — 09:58 AM
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
There are currently 472 online users. [Complete List]
» 4 Member(s) | 468 Guest(s)
AvatarAvatarAvatarAvatar
