Philco 37-690 C134, 134A descrepancy (Discriminator)
Hi to all!
Been lurking for quite awhile reading all the great posts when I finally have a question for the expertsIcon_angel
While recapping C134, 134A I noticed the cap design doesn't match the schematic.
There are three wires from the metal canned cap mounted on top of chassis wired below.
Brown, red and White/ Black stripe wires and common ground to the metal can itself.
Attached is a diagram I made up to more easily see the problem.
Anyone found this additional cap in their rebuild?
camman
I would tend to replace what is there, a .22 could sub for the two .1 paralleled, and a .1 for the othr one. Use 630 volt types so you do not have to keep so many differrent ones around. The three should easily fit in the old can. Changes, doeumented or otherwise, were often done in production.
(03-19-2012, 02:50 PM)codefox1 Wrote:  I would tend to replace what is there, a .22 could sub for the two .1 paralleled, and a .1 for the othr one. Use 630 volt types so you do not have to keep so many differrent ones around. The three should easily fit in the old can. Changes, doeumented or otherwise, were often done in production.
Thanks codefox1,
This appears to be an early unit with a couple "update" resistors missing.
I think I will keep all existing wires as designed, too.
Yes, I always use 630V caps. Like you said....
no reason not to!
camman
I have recapped this large Marconi model 86.  It plays quit good.         I have stripped the cabinet and using Mohawk...Dan Walker — 12:18 AM
Table radio 51C or 52C?
I think what you may have is another Phactory Phranken Philco, if the holes in the front panel lined up it was not unusu...Arran — 10:41 PM
Ho OSanders, Sorry, I got really busy in May and haven't seen your thread in a while.  I am VERY sorry about that.  ...MrFixr55 — 10:30 PM
Philco 45L Initial Check Up
Dan; I don't think that the model 45 is especially know for coil problems, not that they can't occur for one reason o...Arran — 10:19 PM
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
