Vibrator For Zenith 6V27 ?
I started working on a Zenith 6V27, a 6 volt farm set. Lucky me, all the shields were on the set, but two of the # 15 tubes weren't in the set... Working on finding one through friends. BUT it looks like I will have to replace the vibrator, which is a Zenith part # 190-6V (a 6 pin synchronous type - 6 volt). Searching Google threads, I say someone mention that the Mallory 256 or 1808/4546 would be a good replacement. Where in the world, or rather who in the world sells vibrators? (Please don't flame me!). I'm already cross-eyed from searching and I sure could use some help.
Thanks!
David
BUICK, used a synchronous vibrator, there are some transistorised vibrators being made for vintage auto radios, they are $$$. You could use a four pin vibrator and use diodes for rectifier. Have you tried buzzing your vibrator on AC ? You do it in line with a 40 watt light bulb
Thanks, I'll try that
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
