Volume control, Model 16
I'm restoring a Model 16 and need a good volume control / switch. This Code 125 model has a 2 meg pot with two wipers(!) Apparently one of the wipers goes to the bass compensation resistor / cap, and it appears to be inverse to the main wiper. This is probably a well discussed issue -- anyone have a good solution? Thanks!!!
David Sligar
Well, gotta get a capacitor in line with the output stage, and the more you cut it off with lower values, more treble. Larger coupling favors bass response to a point. If the tone pot is partially open. might be the case.
Anybody know where to get a replacement pot? Only other thing I can think of would be to use a dual pot -- 1 meg would probably be OK -- with a switch.
Any other ideas?
Thanks!
Contact Mark Oppat at the web address below.
http://oldradioparts.net/controls.html
You could use one that is tapped. It acts as a loudness control. Give a bit bass boost at low volume.
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
