Silvertone Model 7048
Need somehelp with the pushbuttons. Finished with chasis and plays well but can not use the buttons. thsy will not move tuner and I am notsure if some mechanical parts are missing. I have the schematis(2) but they give no information of buttons. Any advise will be greatly appreciated.
Vaguely remember working a on Silvertone like yours with same problem. Its a mechanical system. It's pot metal I'm sure and likely an actuator has broke off.
Thank you for the reply, and that is the problem.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 332 online users. [Complete List]
» 1 Member(s) | 331 Guest(s)
