Philco Model 048 Tester
I could not pass up the chance to buy this 048 multi-tester but in order to attempt to get it working I need to address the battery issue. It has 2 Burgess #5156 22.5v 15 cell batteries and one #2. I figured out the #2 is a D cell but I am not sure what to do for the the others. Has anyone built this type of battery pack? My main concern is do I use AA, C, D build?
While searching the site I noticed a fellow named Batterymaker...If you are still out there, do you make these or have instructions of the best way how to?
Thanks Everyone!!
Batterymaker (Bill Morris) is very busy right now remodeling his house. It is my understanding that he will no longer be making reproduction batteries that use modern C or D cells and 9V cells inside, but he will be selling the info to make your own.
Give him a shout. batterymaker at gmailspam dot com (remove the spam before sending)
I have the 048 schematic w/ part values, and test procedures.
Use standard order form on my site in Schem. Info page.
Chuck
Thanks Chuck....the order is placed and check is in the mail
Ben,
Your order email from The Philco Repair Bench Schematic Info page has not shown up yet, FYI.
Will watch for it.
Chuck
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
There are currently 628 online users. [Complete List]
» 1 Member(s) | 627 Guest(s)
